Author Topic: F/S WG U2000 Chassis Certified like new AL / Birmingham ; Montgomery.  (Read 1615 times)
mvsfan
  • Last login:May 26, 2016, 08:05:26 pm
What we have here is a Wells Gardner U2000 Monitor chassis, with Monitor frame available if requested. It has had a Cap kit and a new remote controller board installed as well as several other repairs made by The Monitor Boss, in Wisconsin, to ensure that it functions as it should new.
My only problem with the whole deal was that it turned out that my Tube itself Is shot. This thing has been completely tested on a good tube, before it left the shop.
I also have a small piece of info for someone who might well have a compatible TV.
this chassis requires a 25" tube, Tube # A63AGD01X or Equivalent, to work.
Many common 25" tvs, and specialty monitors were shipped with this tube, or an equivalent and with the monitor Frame, Chassis, Cage, whatever you want to call it that i will send if you request it, you should be able to take the tube out of your old 25" TV, providing that it matches, and bolt it right into an for all purpouses remanufactured monitor chassis.
Thanks, and I am open to all offers over $190. The first person who comes up with the dough paid in full gets it. This is turn key, all you need is a tube. I would even be willing to offer a square trade warranty if this buy wasnt so dependent on correct user installation.
SO i cant do that. I can however provide you with the detailed repair reciepts on this chassis.
mvsfan
Re: F/S WG U2000 Chassis Certified like new AL / Birmingham ; Montgomery.
« Reply #1 on: March 17, 2010, 10:19:38 pm »
I also had no luck at all whatsoever with the TV's that ive been saving. none of the tubes were compatible. The worst thing is that i threw away a 1987 NEC tv several years ago cause the electronics had finally crapped out, and it had a compatible tube. i just didnt see the need to keep it anymore.
