Author Topic: WinUAE Loader question  (Read 2593 times)
zubaran
  • Last login:March 15, 2010, 10:11:28 am
« on: March 12, 2010, 09:44:02 am »
Hello everyone,
Actually i'm using WinUAE and loader.
When i start a game who get more than one disk i was thinked with loader and zipped games format disk change automaticaly, no ?
Because in game they asking to me disk swapping, i must press F12 and change disk....  :dizzy: Is a way to automaticaly swap disk ?
An example :
This is my data xml configuration on WinUAE Loader :
  <Game Name="Alien Breed" FileName="Alien_breed.zip" ScrnshotFilename="A/Alien_Breed.png" UseMouse="False" PalNTSC="0" NumDisks="2" UAEConfig="kickstart_rom=v1.3|nr_floppies=1|floppy0type=0|floppy1type=-1|floppy2type=-1|floppy3type=-1|immediate_blits=false|ntsc=false|chipset=OCS|collision_level=playfields|fastmem_size=0|bogomem_size=2|chipmem_size=1|cpu_speed=real|cpu_type=68000|cpu_compatible=false|cpu_cycle_exact=false|blitter_cycle_exact=false|statefile=savestates\0998_Alien Breed.uss" />
My zip file "Alien_breed.zip" contain disk1 and disk2 adf format. Why they asking me to change disk when i'm playing ?
Thanks  :afro:
headkaze
  • 0x2b|~0x2b?
Re: WinUAE Loader question
« Reply #1 on: March 12, 2010, 11:16:28 am »
In WinUAE Loader under the input tab is where you can set the disk swapper key. It will rotate through the disks when you press it.
« Last Edit: March 12, 2010, 11:40:12 am by headkaze »
zubaran
« Reply #2 on: March 12, 2010, 12:21:10 pm »
Hey Headkaze, thanks for your answer !
I've not seen this, thanks ! But i have configured a key and in the game when i press it nothing append and disk not change. Have you an idea why it doing this ?
EssexMame
  • Last login:February 05, 2026, 08:12:04 am
  • Mame Weekender
« Reply #3 on: December 14, 2013, 04:29:23 am »
For Alien Breed, you need to press Ctrl (fire on joystick) after pressing the Disk Swap key (default P). This then runs the new disk and loads the game
