Author Topic: Xbox to Jamma Convertor...  (Read 3337 times)
wild_eyed
  • Last login:September 09, 2020, 06:05:39 am
« on: March 05, 2010, 10:46:10 am »
i know the xbox isnt pc hardware but i figure someone here might be able to help me....
the xbox to jamma convertor is the one seen here:
http://www.arcademvs.com/VIDEO_ACCESSORIES.htm
my monitor is a wells gardner 19k7601
my images are displaying white fuzz. but the games are displaying decetntly
on the jamma connector there are 5 pins relating to the video
Red
Green
Blue
Ground
and
Sync
the first four are fine i.e. i know where they go,
but on the monitor there are four places were the sync pin could go.
previous games send it to -H sync on the monitor
im sending it there now for the xbox as well
but there are also +H sync -Vsync +vsync that go unused.
any help would be greatly appreciated
Re: Xbox to Jamma Convertor...
« Reply #1 on: March 05, 2010, 11:40:43 am »
tie the sync in with the last 2 pins H and V sync, thats how I had to do it with soft 15 and a break out cable on my wellsgardner
wild_eyed
« Reply #2 on: March 05, 2010, 01:10:31 pm »
just to clarify, do you mean, take the single sync from the jamma and connect it to -V Sync and -H Sync on the monitor?
« Reply #3 on: March 05, 2010, 02:05:03 pm »
yes
wild_eyed
« Reply #4 on: March 05, 2010, 06:53:22 pm »
ok will try this tomorrow
wild_eyed
« Reply #5 on: March 08, 2010, 09:54:18 am »
hi again.
i connected the i connected the -h sync and the -vsync of the monitor to the sync of the jamma but i still got the same line sthrough the monitor.
the pins on the monitor are as follows
1 Red
2 Green
3 Blue
4 Ground 1
5 +V Sync
6 +H Sync
7 Ground 2
8 -V Sync
9 -H Sync
wires from the jamma are:
Red
Green
Blue
Ground
Sync
Wires are running as follows:
Jamma             Monitor
Red ----------- Red
Blue ----------- Blue
Green ---------- Green
Ground --------- Ground 1
                      +V Sync
                       +H Sync
                      Ground
Sync ----------- -VSync & -HSync
Should i be connecting the jamma ground to the other ground on the monitor?
thank you.
« Reply #6 on: March 09, 2010, 08:37:50 pm »
no no the + syncs, should be at the end of RGB connector.
