Author Topic: UltraStick 360 reprogramming question [Ginsu fixed it in 7 min]  (Read 983 times)
Sir Headless VII
  • Last login:April 30, 2017, 02:04:52 pm
I have an Ultrastick 360 and have now realized that the way I routed my cp and the default up are at odds (I wanted what is default left or right to be up and down). Is there a quick way to rotate all the maps 90 degrees or will I have to go through manually and change every mapping myself?
« Last Edit: March 03, 2010, 11:54:04 pm by Sir Headless VII »
Ginsu Victim
  • Comanche, OK -- USA
Re: UltraStick 360 reprogramming question
« Reply #1 on: March 03, 2010, 11:43:13 pm »
Would taking the PCB off and changing which way it's mounted help? That's what I would do. Just rotate it.
Sir Headless VII
« Reply #2 on: March 03, 2010, 11:53:30 pm »
Yes it would help. Problem Solved in 7 minutes. I love this place. Thank you Ginsu.
