Author Topic: is it possible to route joystick hole without router...  (Read 2842 times)
animatorJustin
  • Last login:January 14, 2023, 11:09:32 pm
« on: March 03, 2010, 03:14:48 pm »
i don't have a router (and to poor to buy one  :cry:)and i am going to be mounting two mag-stik plus and a track ball. is it possible to do this with a chisel :-\, i know it might suck, or take a long time, but does anyone have any tips or things to watch out for when doing this.
garnerb350
    • Hyperspin
Re: is it possible to route joystick hole without router...
« Reply #1 on: March 03, 2010, 03:23:11 pm »
Are you using wood?...
spade-bit? joystick hole should be the same as a button...
jig-saw? (trackball)
Check with Harbor Freight...they have tools cheap...Maybe also check around pawn shops... :dunno
using a chisel is risky...
1. You could end up gouging too much...and chance of being uneven...
Dremel kit...then buy the router bits...
Know any friends you can borrow tools from?
animatorJustin
« Reply #2 on: March 03, 2010, 03:36:30 pm »
sorry 3/4 mdf board. i drilled a joystick hole, but i want the joystick longer. me and all my friends are computer animators = no tools or woodworking experience
« Last Edit: March 03, 2010, 03:38:12 pm by animatorJustin »
« Reply #3 on: March 03, 2010, 04:19:22 pm »
dremel is your best/cheapest bet, unless you have a chisel and a lot of free time.
animatorJustin
« Reply #4 on: March 03, 2010, 04:22:03 pm »
i do have a chisel, i was wondering if anyone has gone down that road
« Reply #5 on: March 03, 2010, 04:26:09 pm »
This is kind of easy but also a pain.  Trace your mounting plate with a razor and press as hard as you can.  Peel away the MDF.  Repeat until you reach your desired depth.  Once you get down like 1/16" you can use sandpaper or something to keep the area as flat as you can.  It's not that hard but it will take a while.
EDIT: A sharp chisel will make it go much faster.  I used one to remove MDF underneath my CP but in the corners only because my router did the rest:
« Last Edit: March 03, 2010, 04:28:48 pm by javeryh »
animatorJustin
« Reply #6 on: March 03, 2010, 04:30:04 pm »
thanks
DrumAnBass
  • Last login:July 10, 2024, 10:36:54 pm
  • "I love this computer magic!" - Viv Savage
« Reply #7 on: March 03, 2010, 06:51:07 pm »
Maybe you could borrow a router? What part of the world are you in?
"Some drink from the fountain of knowledge; I only gargle."
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #8 on: March 04, 2010, 04:47:46 am »
as a router alternative u can try a drill press with a router bit. its not that easy 2 handle but it works .
animatorJustin
« Reply #9 on: March 04, 2010, 09:01:46 am »
Philadelphia, Pa i tried a chisel...  :banghead: it worked but took 2 hours for one even hole
« Reply #10 on: March 04, 2010, 09:27:32 am »
1 down, 1 to go?  2 hours is better then I did my first time, took me almost 3. Do it a bit at a time, chip away at it /pun.
it'd take you that long (or longer)  to drive to my house for me to route the holes for you. I think you can rent one from Home Depot. What kind of animation do you do?
Ed_McCarron
« Reply #11 on: March 04, 2010, 10:00:29 am »
Crap.  I'm just south of Philly but my router is already out on loan...
Check out this place:
http://retoolpa.com/
It's up 95N near Sesame Place...  Great prices on used tools.
animatorJustin
« Reply #12 on: March 04, 2010, 10:33:59 am »
3D animation, right now mostly medical presentation, my heart is  in character animation and special effects
severdhed
  • Last login:Today at 04:48:59 pm
  • RIP Dinosaur Hippo
« Reply #13 on: March 04, 2010, 12:43:50 pm »
You can buy a router at harbor freight for $25...it is a small trim router and it works great.  Sure it is not a name brand unit, but it works great.  I have had mine for a little over a year and have used it on numerous projects, both arcade related and otherwise, and it has performed very well.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=44914
garnerb350
    • Hyperspin
« Reply #14 on: March 04, 2010, 12:57:42 pm »
+1
Also that dremel kit is pretty nifty...I use that for making signs and small work that requires routing...
