Author Topic: Monitor problem.. what do you think?  (Read 2207 times)
JoeB
  • Last login:February 07, 2026, 01:46:15 pm
  • NES Fanatic
« on: July 26, 2003, 06:37:24 pm »
I have a WG 25K7191 that I use with ArcadeVGA..
I also have a JAMMA board, but both the original board, and the PC emulated games show the same problem..
The best way to describe it is 3-5 1/2" stripes that go down the left half of the monitor.  The thing about them is that they're not colored.. they're just change in tint..
If I bring the brightness down, they almost disappear, but when I bring it up, they're visible.  When I play the game I don't notice them unless I look for it...
Was wondering if this is due to a tube being "tired" or maybe do I need to re-cap for board for it??
Any advise/suggestions would be highly appreciated.
Thanx
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:Monitor problem.. what do you think?
« Reply #1 on: July 27, 2003, 05:46:49 pm »
Sounds like it needs a cap kit. Not positive though.
OSCAR
  • Last login:September 06, 2018, 11:31:53 pm
  • I think Bigfoot is blurry, that's the problem...
    • Oscar Controls
« Reply #2 on: July 27, 2003, 06:45:54 pm »
I agree with Tom61, it definitely sounds like your monitor needs a cap kit.  It sounds like you are describing "jail bars", an example pic of this can be seen here:  http://www.arcadeshop.com/pics/sanyo-jail-bars.jpg
Note that the size and frequency of jail bars varies depending on the condition of the caps in your monitor, but what you describe is a common problem with older monitors.  When in doubt, cap it...  :)
Also make sure you have a good ground connection to your monitor frame, and between the monitor chassis and frame.  Sometimes a faulty ground strap can cause weird anomalies in your picture.
JoeB
  • NES Fanatic
« Reply #3 on: July 27, 2003, 11:11:22 pm »
I think you're right..
Now, I'm really good at fixing electronics, working a soldering iron, etc.. so doing the actual recap would be quite simple for me..
my only concern is taking the board out and putting it back in.. (the electronics I work with have 12v max.. not 1000!)
Are there any instructions in regards to how to do it properly? especially for this monitor??
JoeB
  • NES Fanatic
« Reply #4 on: July 27, 2003, 11:29:14 pm »
Here's a clean picture of the effect
JoeB
  • NES Fanatic
« Reply #5 on: July 27, 2003, 11:29:38 pm »
and another..
OSCAR
    • Oscar Controls
« Reply #6 on: July 27, 2003, 11:34:55 pm »
Here are a couple of sites that do a step-by-step...
http://www.arcadeobsession.com/capkit.html
http://todd1814.www3.50megs.com/capkit/capkit.htm
Not much is different between different monitors when re-capping them.  Just the basic safety precautions is the most important thing to keep in mind.  Bob Roberts includes a "cap map" where all the included caps in the kit go on the chassis, so you should have no problem with it.
« Last Edit: July 27, 2003, 11:36:47 pm by OSCAR »
Ken Layton
  • Guru
  • Technician
« Reply #7 on: October 26, 2003, 01:49:12 am »
It looks like a cap kit would be the thing to do.
