Author Topic: 'malakeyhook.dll not found' ?  (Read 3387 times)
I/O
  • Last login:June 06, 2011, 01:33:10 am
« on: March 02, 2010, 04:34:09 pm »
I have this in the mala directory, yet in the options menu in mala it says it is not found. When I use this for Visual Pinball, it works only half way. Vpinmame stops, but the table does not close. My anti-virus did not like the file, even after I made it an exception. Could my anti-virus be interfering?
« Last Edit: March 06, 2010, 02:18:00 pm by I/O »
Eddie_Brock
  • Last login:February 26, 2014, 12:00:34 pm
Re: 'malakeyhook.dll not found' ?
« Reply #1 on: March 07, 2010, 12:51:29 pm »
Are you on Windows XP or later?
It specifically states that its not needed if you are on XP (and I would assume win7 as well)
I too was trying to figure this out...we need to use windows Hotkeys instead.
I/O
« Reply #2 on: March 09, 2010, 01:18:26 am »
XP. It was suggested to use keyhook with Visual Pinball to avoid the options window when the exiting key is pressed.
loadman
    • MaLa
« Reply #3 on: March 12, 2010, 04:48:07 am »
Grab an old version of mala from the mala website, it has that crappy dll
