Author Topic: Reverse Aimtrak sensor bar  (Read 2188 times)
gman314
  • Last login:July 02, 2013, 03:12:39 pm
« on: March 01, 2010, 08:10:46 pm »
Will Aimtrak still function properly if I "reverse" the sensor bar?  In other words, the 5 LEDs would then be on the right side, and the 1 lonely LED would be on the left side.  Something tells me that the answer is no.  Did anybody try this?  The sensor bar will fit better in my cab if it is reversed.
animatorJustin
  • Last login:January 14, 2023, 11:09:32 pm
Re: Reverse Aimtrak sensor bar
« Reply #1 on: March 01, 2010, 11:26:31 pm »
i was having difficulty getting it to track the gun, and ended up finding out that i had it reversed, i don't know if it is 100% necessary that it is in the "correct way" but once i corrected it, it fixed all of my issues of getting it to work properly.
gman314
« Reply #2 on: March 02, 2010, 12:49:01 am »
When I tried to reverse it earlier, about 1/4 of the screen was inaccessible.  And just like you said, when i switched the sensor bar back to the "normal" position, I no longer experienced this problem.
