Author Topic: Cool little program.....  (Read 3093 times)
P-Funk
  • Last login:August 30, 2003, 01:50:44 pm
  • Mmmmmm, Beer.......
« on: July 26, 2003, 05:42:06 pm »
Hey all,
I recently found myself in a position of having to unzip several thousand roms files.  I found a cool little program called 'Unzip Them All'.  It worked great for me.  You can grab it here.
http://www.herve-thouzard.com/unzipus.phtml
Word of caution though:  It defaults to creating a sub directory for each unzipped file.  Doh!  So change that setting first.
AlanS17
    • AlanS17
ROM zips vs. individual folders
« Reply #1 on: July 26, 2003, 05:54:17 pm »
How beneficial would it be to have every MAME rom open in its own folder rather than using the ZIPs? I wonder i it could substantially increase loading times...
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:Cool little program.....
« Reply #2 on: July 28, 2003, 03:13:12 am »
And if you unzip the ROMs, the files need to be in their own folders with the same name as the zip file, anyway.
I say keep them zipped, though.  (Depending on the CPU speed vs the harddrive speed) Many modern computers can load and unzip a zip file faster than loading the same files (as in the zip file) unzipped on the same harddrive.  Plus the disk space you save, CMPro, and copying/backing up, why unzip?  *shrug*
Robin
Knowledge is Power
P-Funk
« Reply #3 on: July 28, 2003, 11:34:27 am »
I used it for my Atari 2600 and NES roms.  Because I was having trouble getting Z26 and Nester to read zip files.  Once unzipped, everything worked great.
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
« Reply #4 on: July 31, 2003, 08:55:24 am »
Oh the world of GUI interfaces. DOS pkunzip wasone of the origanel compression tools and it could handle an entire directory of zips to be unzipped at one time...
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #5 on: August 08, 2003, 08:27:34 pm »
winRAR allows you to unzip multiple zip files. I use this program for everything compression related. Much better than winZIP
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
« Reply #6 on: August 08, 2003, 10:52:36 pm »
CitznFish is right.  Plus, WinRAR gives you the ability to unzip multiple archies into their own directory with the same name as the zip filename anyway.
Best archiving/unarchiving utility I've ever used.  By far.
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
_Iz-
  • Last login:Today at 12:28:03 am
  • Time to coin up!
« Reply #7 on: August 14, 2003, 03:12:09 pm »
Winzip will unzip multiple files at once.
You select them all in windows explorer, right click somewhere in the highlighted area and then in the pop-up menu choose winzip -> extract to (here)...
IceCold
  • Last login:March 22, 2010, 05:11:22 pm
    • My MAME cabinet webpage
« Reply #8 on: August 15, 2003, 09:12:19 pm »
winace does the same thing too.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #9 on: August 16, 2003, 12:53:12 am »
why?
