January 23, 2026, 12:47:02 pm
SET A RESTORE POINT. (speaking WinXP here)I personally had troubles with the UNDO feature not undoing all that it did.Others seem to have good results with it.
If you run instant sheller by Tom Spiers and shell your frontend you CAN undo ALL changes by running the application again and pressing the undo changes button.
What particular part of undo failed?
