Author Topic: SLIKSTIK Settings?  (Read 1545 times)
NatasNJ
  • Last login:December 19, 2003, 04:10:03 pm
SLIKSTIK Settings?
« on: July 26, 2003, 02:15:51 pm »
Hey..   Got my CO2 Slikstik last night.  AWESOME.  Having some problems though.   How do you adjust sensitivty for the mouse & spinner?  I am using Mame32 (.70 & .71)I tried in the controllers menu for the games (joypad thingy) also turned up mouse speed in control panel all the way up.  My trackball and spinner still don't react fast enough.  Thanks..
Also do I have to manually select ENABLE mouse for EVERY game to be able to use the trackball  spinner?
Just wondering if there was a more automated setup available for MAME32.
*still working on setting up MAMEWAH as frontend.  Just can't figure it out..
SlikStik-Christian
  • Last login:November 04, 2004, 10:28:08 pm
  • Gaming will never be the same...
    • SlikStik Arcade Controllers
Re:SLIKSTIK Settings?
« Reply #1 on: July 26, 2003, 03:20:24 pm »
NatasNJ,
   You can adjust the speed sensitivity directly in Mame, go to our website and click on the FAQ web page on the left. At the bottom you will see the question The spinner seems to be moving too slow in Mame, can I speed it up? which should solve that.
As for having the spinner enabled (in all games that require it) at the same time, you have to enable Mouse Support in Mame. Do this by launching Mame, go to options on top, then to default game options, then to controllers, then put a check in enable mouse input.
« Last Edit: July 26, 2003, 03:27:47 pm by SlikStik-Christian »
Thank You
Christian
SlikStik Customer Support
http://www.slikstik.com
The Worlds Best Arcade Controllers
NatasNJ
« Reply #2 on: July 26, 2003, 04:33:32 pm »
I was planning to try that.  But the tab does nothing for me in the game.  NO menu pops up.  WHy?
Also in Smash TV in game .70 my controls work fine.  But when I go into .71 I lose complete control of the 2nd set of CO2 controls (top fire ones)  I tried copying my slikstik.cfg & smashtv.cfg files over but still nothing..
Am I am doing this wrong?
SlikStik-Christian
« Reply #3 on: July 26, 2003, 10:11:41 pm »
Yes, do me a favor, email us at info@slikstik.com with your phone # and a good time to call on Monday and I will call you and walk you through it.
Thank You
Christian
