Author Topic: Makvision M2929D High res.  (Read 7774 times)
Nips916
  • Last login:October 28, 2017, 07:50:52 pm
« on: February 23, 2010, 06:12:49 pm »
I just received this arcade monitor from Happ.
http://www.happcontrols.com/monitors/49271700.htm
It's hooked up to a windows xp based PC with a Nvidia GT240.
I am unable to get it to display in 1024 x 768. Keep getting over specification.
I have looked all over for some type of information about this monitor but have come up empty handed.
Does anyone have any ideas?
MonMotha
Re: Makvision M2929D High res.
« Reply #1 on: February 23, 2010, 06:15:12 pm »
Make sure you're attempting to use 60Hz.  The monitor can do higher refresh rates, but not at 1024x768.  It can only do 1024x768 at 60Hz.  Windows doesn't always make the refresh rate obvious.  You will need to go to "Advanced->Monitor" to pick refresh rate.
Nips916
« Reply #2 on: February 23, 2010, 06:43:50 pm »
Ive double checked the 60hz and still get nothing.  I did notice in the manual that there are 2 model M2929Ds.  the M2929D-72 and M2929D-62
the 72 has a resolution of 800x600 while the 62 is the 1024x768.  Could I have the wrong one?
grantspain
« Reply #3 on: February 23, 2010, 06:47:51 pm »
you should have a model number on the chassis board somewhere,do you have an on screen display?
Nips916
« Reply #4 on: February 23, 2010, 06:57:56 pm »
I do have an OSD but it says nothing about model information.  Lemme check the chassis
Nips916
« Reply #5 on: February 23, 2010, 07:14:13 pm »
So the back list the model number as the M2929D-72 which is the 800x600 version.
Did I get Gyped?
Nips916
« Reply #6 on: February 23, 2010, 07:31:09 pm »
Here is a copy of the manual and chassis sticker.
  • Last login:Yesterday at 03:44:11 pm
« Reply #7 on: February 23, 2010, 07:58:20 pm »
Did I get Gyped?
quite possibly... i would check your order and waybill and see if the 72 or 62 suffix is present
edit: fixed quote
« Last Edit: March 25, 2011, 02:45:42 pm by lilshawn »
MonMotha
« Reply #8 on: February 23, 2010, 08:01:23 pm »
Yup, looks like you got the wrong version all right.  Check your order and give Happ a call.
Nips916
« Reply #9 on: February 24, 2010, 03:48:22 pm »
Yep, HAPP says they no longer carry the models capable of 1024 x 768.  They only carry the med res version.  I'm going to make sure they give me a full refund shipping and all.
