Author Topic: GGG Electric Ice-T Trackball Question (wiring)  (Read 1554 times)
Underhill
  • Last login:November 16, 2010, 06:47:19 am
« on: February 21, 2010, 12:27:32 am »
I've searched all over the forums for an answer to my question but to no avail.  I'm posting here since I'm hoping to get a quick answer from someone that happens to own an Electric Ice-T trackball.  If not I'll shoot Randy a PM or email.
I have a GGG Electric Ice-T Trackball (USB) and have everything wired up to the LED Wiz +GP.   The wires coming from the trackball itself are all connected to a small circuit board but one.  The one that is not I am assuming is the ground.  It has 2 green wires really but both are going to 1 ring terminal connector.  These are the wires coming out of the trackball housing itself NOT the rgb lighting.
My question is... What do I connect the green wires to?  Do I need to connect it to a ground on the PC (not sure how to go about it if so)?
Thanks in advance.
fallacy
  • Last login:November 12, 2025, 07:48:56 pm
Re: GGG Electric Ice-T Trackball Question (wiring)
« Reply #1 on: February 21, 2010, 01:55:15 am »
I did not connect the ground to anything. It is basically a USB mouse why to I need a ground for it  :dunno
Underhill
« Reply #2 on: February 21, 2010, 02:02:48 am »
Sounds good.  Thank you fallacy.
