Author Topic: About to buy LCD screen but need some help.  (Read 2388 times)
JensYmer
  • Last login:April 18, 2010, 01:46:33 pm
« on: February 17, 2010, 06:48:42 am »
Hi there
I am currently working on my first cab and is about to buy a LCD flat to place in it. I am quite new to all of this and not that well into specs of screens etc. I was just wondering if there is anything I absolutely should be aware of like does the monitor have to be <12ms etc to run with certain games? I am going to but a 19" screen btw.
Hope someone can help a newbie in need :)
Thanks in advance
« Last Edit: February 17, 2010, 07:34:20 am by JensYmer »
  • Last login:Yesterday at 04:23:32 pm
Re: About to buy LCD screen but need some help.
« Reply #1 on: February 18, 2010, 07:36:06 pm »
don't plan on using light guns on a lcd :(
i wouldn't worry too much....if it fits, and will hookup to your rig.....go with it
Blanka
« Reply #2 on: February 19, 2010, 04:03:10 am »
-Do you want 4:3 or WS?
-Response time is pretty useless information
-Input lag and moving-image artefacts are much more important, and never told in specs.
19 inch non wide screen is not 4:3 either, it is 5:4
19 inch TN panels should not be mount vertical.
The best LCD for vertical classic use is the HP LP 2065 or the Dell 2007FP (non-W model).
These are true 4:3, IPS (wide viewing angle) screens with low input lag and good game response.
JensYmer
« Reply #3 on: February 19, 2010, 04:10:17 am »
Ok, thanks both for the help.
Blanka: I am going to buy a 4:3 screen and thanks, I will look at that screen.
Cheers both again
