Author Topic: Shut Down Windows with Joystick?  (Read 4520 times)
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
« on: February 12, 2010, 11:59:42 pm »
I hacked an XBOX controller to USB and loaded the drivers.  So I have a USB joystick.  anyone know of a trick to shut down a PC by a series of Joystick buttons or something?
I just have mouse and joystick and don't really want to hack a keyboard or add a $40 encoder for a couple more buttons that I can easily solder into my xbox controller hack.
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
Necro
  • Last login:November 29, 2022, 08:22:22 pm
  • Building a 'Classic' MAME Cab
Re: Shut Down Windows with Joystick?
« Reply #1 on: February 13, 2010, 12:10:16 am »
I'm pretty sure you could get something to work using AutoHotKey.
Havok
  • Last login:August 18, 2025, 12:44:57 am
« Reply #2 on: February 15, 2010, 09:28:58 am »
Do you really want to do that though? I can see a heated game of Street Fighter going, and then all of the sudden... The system turns off...
 :angry:
Just use a cheap momentary contact switch wired to the power button connection on the motherboard. Setup Windows to power off when the button is pressed, and you're all set.
Level42
« Reply #3 on: February 15, 2010, 05:21:35 pm »
I actually think using a joystick to shut down Windows is an excellent idea. May I suggest a Berzerk joystick and a throwing distance of about 3 meters ?
 :angel:
allroy1975
  • I'm a dork!
    • Matt's Mame
« Reply #4 on: February 15, 2010, 05:47:25 pm »
 :angry:
It's a road Blasters cab.  Only a steering wheel, 4 buttons and a pedal.  Wanted to hook up the admin buttons for that.  although..I'm thinking about putting a spy hunter shifter on it...so maybe a few more buttons.  Just not sure if I can get it configured well...
  • Last login:July 11, 2025, 09:17:44 am
« Reply #5 on: February 15, 2010, 06:29:20 pm »
The Front End Maximus Arcade supports this feature.
Simply map the keys/buttons you want to shut down (#10 in diagram):  How to map keys
Then set a delay so that when you hold down those keys/buttons it will shut down (#3 in diagram):  How to set delays
DeLuSioNaL29
« Last Edit: February 15, 2010, 06:33:01 pm by DeLuSioNal29 »
allroy1975
  • I'm a dork!
    • Matt's Mame
« Reply #6 on: February 21, 2010, 06:42:38 pm »
You can define a custom combination of two keys (except joystick buttons) by using " & " between them. In the below example, you would hold down Numpad0 then press the second key to trigger the hotkey:
Damn  this is exactly what I wanted to do.
Do I really need a front end for 1 game?  ;)
I currently have a batch file in the startup folder on this cab that reads:
mame roadblstr
shutdown -s -t 00
so it starts the game, then when you hit escape it shuts down windows.  That'd be great...if I had a way of hitting escape.  I could have used mouse buttons, but at this point....the mouse buttons are wired into the buttons on the steering wheel.  I'm just not gonna redo all that.  it was a pain in the A the first time.
any other ideas?
allroy1975
  • I'm a dork!
    • Matt's Mame
« Reply #7 on: February 21, 2010, 11:17:12 pm »
anyone good at this?  Can't figure out why this isn't working:
~Joy1::
tt=0 ; set time to 0
loop,10000 ; check every 30 ms
      GetKeyState, state , Joy1, p
   if state=U
       Break
   tt+=30
   sleep 30
if tt>5000  ; if key pressed more than 5 secs
   Send {Esc}
   sleep 2000
Tooltip
return
Works fine in Windows..but when I'm in MAME, it doesn't get the "esc" keypress.  pretty frustrating.
allroy1975
  • I'm a dork!
    • Matt's Mame
« Reply #8 on: February 21, 2010, 11:32:08 pm »
well, it's ugly...but...it works.  if the coin button (Joy1) is held down for more than 5 seconds, it kills mame, then my batch file finished running..shutting down windows.
I could of course just change the batch file to not shut down windows and instead set the script to
run, shutdown -s -t 00
but..whatever
~Numpad1::
      GetKeyState, state , Numpad1, p
   if state=U
       Break
   tt+=30
   sleep 30
Run, taskkill /IM mame.exe
sleep 2000
Tooltip
return
allroy1975
  • I'm a dork!
    • Matt's Mame
« Reply #9 on: February 25, 2010, 10:29:34 am »
not sure if anyone here cares really....but....running this script was killing mame and in Road Blasters, it wasn't saving my high scores.  weak.
So I'm documenting (for myself) and sharing in case anyone else wants such a script.....
I changed my AHK to run:
~Joy1::
loop,10000 ; check every 10 seconds
   if state=U
       Break
   tt+=30
   sleep 30
   IfWinExist, MAME
       WinActivate
         Send {Esc Down}
         sleep 1000
return
bkenobi
« Reply #10 on: February 25, 2010, 11:20:55 am »
Does that last script send the escape key to MAME correctly?  I wasn't aware that you could send keys from AHK to MAME with the RAW input system.  If it works, that would be really nice to know!  I was pretty sure you needed to compile MAME with the RAW input system disabled, but of course if this does work then I'm wrong!   :cheers:
allroy1975
  • I'm a dork!
    • Matt's Mame
« Reply #11 on: February 25, 2010, 03:57:05 pm »
I was just reading in another long winded thread about "new versions of mame only take raw input" or something when talking about passing coin input from a FE to the mame exe.  That was the first I had heard of it.
I was running into speed issues with the newer versions of mame, so I dropped back to like .85 and it seems to be working fine.
but..in older versions (where you can skip the legal info and rom info  :applaud: ) it seems to work.
you should be able to replace "Joy1" with anything.  A key on the KB or whatever.
I was going nuts last night with this...instead of using {Esc Down} I was sending it like... 500 escape keypresses..sometimes it would work and sometimes it wouldn't.  I was going nuts.  then i remembered the down (holds the button down) and bam.   success.  I love figuring stuff like that out..but I wasted literally HOURS trying to do it the wrong way. :dizzy:
bkenobi
« Reply #12 on: February 26, 2010, 03:24:18 am »
Yes, this will work with versions of MAME older than ~0.117.  If you try it with versions more recent than that, you will not see any input to MAME from the AHK script unless you compile your own version of MAME to not use the RAW input scheme.  I was just making sure things hadn't been changed somehow.  Thanks for the response!   8)
allroy1975
  • I'm a dork!
    • Matt's Mame
« Reply #13 on: February 26, 2010, 12:35:57 pm »
now...I don't know what I'm talking about...but this AHK script is REALLY cool in my opinion.  I always have kids...(and some adults  ::) ) pushing buttons all over the place.  I usually set up button combo's to do admin features.  That way only I can access them.
Unfortunately someone will hit the same buttons I have set up.  So having a script that says you have to do something for X seconds seems like a more stable options.   People don't set their drinks down...ON BUTTONS!
so...I don't know if this would work, but AHK does have a SendRaw option.  I haven't tested but it's simply adding 3 more characters to the script:
~Joy1::
   if state=U
       Break
   tt+=30
   sleep 30
   IfWinExist, MAME
       WinActivate
         SendRaw {Esc Down}
         sleep 1000
return
any idea if that would work on newer mame builds?
