December 01, 2025, 12:05:59 am
The Ultralux micro switches are mounted horizontal instead of vertical.Encryptor
The Ultralux buttons are lighted so you'll have to pull out the socket (should just pull straight out) for the bulb before you can get to the plunger and remove it similar to the diagram Havok posted. The Ultralux micro switches are mounted horizontal instead of vertical.
FYI, the socket doesn't come installed on Ultralux, so it shouldn't be an issue.
