I did find out that legs 3 and 4 of T2 are shorted to each other. Is that how it's supposed to be?
well yes and no...
it's a transformer, it's not really supposed to have resistance in it, otherwise you would be wasting energy, effectivly to test a transformer you need to test between the coils...in this case seeing if there is a short between them... in this case 1/2 is one coil and 3/4 is another.... so test between 1/3 or if you like 2/4 or 1/4 or 2/3 (you only need to do one.)
Well, I removed R103 from the circuit and it read 01.1 ohm. That's a short in my book. It's supposed to read 2.7 ohms. It reads 3.1 in the circuit, but 01.1 out of the circuit. I'll replace it and see what happens.
resistors, when stressed don't typically lessen in resistance, they go up in resistance...replace it though.
my thoughts for further diagnosis:
since you stated first that you shorted r301 to the chassis ground...i would concentrate on everything UPSTREAM of the resistor... this includes...
r103
ic4
r84, r85, r86
c55, c56, c57, c59, c60, c61 (59, 60, 61 should read open)
d19, d20, d21, d22 (i know you checked them, but be sure..on DIODE check setting of your multimeter...they should all read nearly identical reverse voltage)
also....
triple check C36 and C38...  the capacitors should both read "open." You'll have to pull them out of circuit to be sure. The value of C36 is 6100 picofarads, 1500 volts. This value may be a bit different in your monitor due to changes in circuit design to accommodate different CRTs and horizontal scan rates. Also, some monitors use a capacitor with four legs instead of the normally found pair of component leads. If you are using a two legged replacement component, you'll need to add a couple of small jumper wires. The value of C38 is .39 microfarads, 200 volts.
if your fuse is still blowing, you have a short someplace in the B+ line or power supply section... you just need to track it down.
