Author Topic: Has anyone Wired up a knocker for Q*bert?  (Read 21377 times)
Jesse
« on: July 09, 2002, 04:24:58 pm »
Does anyone know if its possible to wire up a Q*bert Knocker in a mame machine to knock at the apropriate time in Q*bert (when he falls off the pyramid) ?? That would be pretty cool. Other wise I will have to buy an original Q*bert, which are very pricey. Thanks in advance for any advice.
Jesse
« Last Edit: December 31, 1969, 07:00:00 pm by 1026619200 »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re: Has anyone Wired up a knocker for Q*bert?
« Reply #1 on: July 09, 2002, 11:08:42 pm »
Yes, I am doing that.
I will try and link a post I started.
I am a software engineer, I know where in the mame code code needs to be added to do it.  I want to make a lpt port interface, but I am no electronics person.  I tried and failed.  I was going to then get this $70 serial port adaptor with relays to do it.
Actually, all the info one where in the code is in the following link too.
If you know electronics I'll do a trade with ya, you make me a knocker, I'll make the code to run it.
Here's the link
http://www.arcadecontrols.org/cgi-bin/yabb/YaBB.cgi?board=main;action=display;num=1016919933;start=37
I still want to do it, just don't have the time and money for the hardware side to make it work.
« Reply #2 on: July 10, 2002, 06:13:28 am »
Sp did you see the new parallel port interface on the main page?  It might help I dunno.
SirPoonga
  • Puck'em Up
« Reply #3 on: July 10, 2002, 08:52:50 pm »
Not really, has my trouble is the harddware side, I just suck at it.  I tried a relay hooked to a solenoid, no work.  not much more simpler than that you can get!
1UP
  • Token Junkie
    • 1UPArcade
« Reply #4 on: July 10, 2002, 11:22:29 pm »
Here's a USB relay mod that will make things easier: http://www.j-works.com/jsb218.html
It is controllable thru c programming, and comes with sample apps.  All you need is a solenoid and a power supply rated to drive it.  I'm getting the 2-relay model for my T2 guns, but you can get a 1-relay mod for $50.
My other job...
Jesse
« Reply #5 on: July 12, 2002, 11:39:38 am »
SirPoonga, Does 1UP's USB relay mod seem feasible? Also I contacted Oscar Controls about this and Kelsey there said that he has been following this topic (he also seems to Know you Sirpoonga)for a while and that he may try to work on it in his free time. Meanwhile I am trying to locate a suitable device to experiment with. Does anyone know if a Pinball type knocker would work? And where can you buy replacements of these from? Or would it be smarter to get old used ones to tinker with? Any help is apreciated. Thanks.
SirPoonga
  • Puck'em Up
« Reply #6 on: July 12, 2002, 01:19:43 pm »
Yeah, but it is a little overkill for since you need just ONE relay, not 8:)  USB would be better for winxp, as you can;t access low-level hardware directly, like the lpt port.
All too well.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #7 on: July 13, 2002, 12:22:07 pm »
My other job...
SirPoonga
  • Puck'em Up
« Reply #8 on: July 13, 2002, 12:43:55 pm »
$50 is still expensive, for one relay.
Anyway, what do you mean hack the ipac?  You mean using the keyboard LEDs?  Well, the way mame handles leds that isn't going to work the way I need it to work.
Anyway, I got an idea and am going to try it out.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #9 on: July 14, 2002, 02:52:29 am »
My other job...
SirPoonga
  • Puck'em Up
« Reply #10 on: July 14, 2002, 11:04:56 am »
Anyway, I'm tired of hacking hardware to save a few bucks.
Dav
  • Last login:March 29, 2016, 05:39:35 am
« Reply #11 on: July 14, 2002, 03:57:55 pm »
Yeah, that's what I did to test my T2 guns.
SirPoonga
  • Puck'em Up
Re:Has anyone Wired up a knocker for Q*bert?
« Reply #12 on: July 14, 2002, 11:14:02 pm »
Like I said, I know where in the code to edit, I don;t want to use keyboard leds, not generic enough
« Reply #13 on: July 15, 2002, 12:18:15 am »
I agree with sp on this one.  If you hack the leds not only is it kinda dangerous, (as a bad wiring job could blow your ipac) but you can't use leds in other games without some sort of kill-switch for the knockers.  Also it would be nice to add a usb interface as it's very xp comp.  Btw I believe the way you interface the leds is different in xp and 9x so that could cause more problems.
SirPoonga
  • Puck'em Up
« Reply #14 on: July 15, 2002, 12:32:00 am »
And only people with ipac and keyboard hacks can benefit from it.  What about gamepad and other encoder hacks...
