Author Topic: Renegade freezes after main screen  (Read 1951 times)
sham69
  • Last login:June 12, 2015, 06:03:44 am
« on: January 20, 2010, 07:26:23 am »
Hi,
Renegade was one of my favs during my arcade days.
I am trying to get it working on mame with no luck.
It starts up and then freezes on the first level after the music?
I have tried with a few different versions of mame.
Is it the rom thats at fault or the version of mame?
Has anyeon got this working?
It does the same on the japanese version aswell by the way.
Cheers.
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
Re: Renegade freezes after main screen
« Reply #1 on: January 20, 2010, 10:25:25 am »
There was an issue some versions ago which was fixed for 0.129.
http://www.mametesters.org/view.php?id=1679
So, anything 0.124-0.128 would not work properly.  Try a more recent version of MAME.  0.136, for instance, seems to work fine.
sham69
« Reply #2 on: January 21, 2010, 07:33:34 am »
Cheers for the reply.
I think I am using 0.128, will upgrade once I get home.
Thanks again.
sham69
« Reply #3 on: January 30, 2010, 06:18:06 am »
Cheers that worked only problem being some other games are not working now...
The VS Super Mario Brothers doesnt work and my 2 yr old is not impressed.
What is the most stable version of mame?
It also seems that Yie Ar Kung Fu has disappeared from my games list since moving to 0.136.
Any suggestions greatly appreciated.
Sham...
Tafoid
  • Emulation Devotee
« Reply #4 on: January 30, 2010, 11:44:09 am »
Sometimes, as you fix other bugs or work on some drivers - things break:
Super Mario Bros (suprmrio):
http://www.mametesters.org/view.php?id=3573  - Fixed for 0.136u1
As for Yie Ar Kung Fu - I have not noticed as any changes to the romset.
There is, however, a noticeable regression in audio though when the clocks were updated which still hasn't been corrected.
http://www.mametesters.org/view.php?id=3371
Not sure why it would disappear though.  I don't use a MAMEUI, just command line or my own front-end.
