Author Topic: Can't Access Mamewah menu  (Read 1809 times)
bigjase
  • Last login:February 23, 2012, 04:23:22 pm
« on: January 20, 2010, 01:45:51 am »
I need to refresh a list in mamewah version 0.96, but when I hit "2" in the list to bring up the menu, nothing comes up. I've tried pretty much every other button and still can't get the menu up. What am I doing wrong?
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 05:07:57 am
Re: Can't Access Mamewah menu
« Reply #1 on: January 20, 2010, 03:12:14 am »
For a start, you're using a very old version of MameWAH.
bigjase
« Reply #2 on: January 20, 2010, 09:17:15 am »
That shouldn't matter, should it? I should still be able to bring up a mamewah list, correct?
Zebidee
  • Trade Count: (+9)
« Reply #3 on: January 20, 2010, 10:20:57 am »
There are differences in the way config files work.
Make sure that your "2" button is actually working properly.
You want to find a mamewah.cfg somewhere I think. It might be in your "/mamewah/config" folder.
Mamewah homepage
http://mamewah.mameworld.info/news.htm
Mamewah forum
http://www.mameworld.info/ubbthreads/postlist.php?Cat=&Board=arcadeospc2jamma
bigjase
« Reply #4 on: January 20, 2010, 12:50:12 pm »
Thanks Zebidee. I'll check that when I get home.
I know I'm running an older verision of mame, but does that matter? I've haven't updated because I don't want to have anythign quit working that worked before.
gonzo90017
« Reply #5 on: January 21, 2010, 01:26:08 am »
If it ain't broke...
Zebidee
  • Trade Count: (+9)
« Reply #6 on: January 21, 2010, 02:41:39 am »
<sigh> I made the comment because it is less realistic to expect support when using an older version of software. New versions usually bring in new bug fixes which may solve your problems without further fuss. And there have been changes to the way Mamewah config files work since v0.96 (or at least where they are located). I honestly don't know for your version.
