Author Topic: TV lost red colors  (Read 1310 times)
Hamselv
  • Last login:May 16, 2010, 08:08:44 am
TV lost red colors
« on: January 18, 2010, 04:37:58 pm »
Hi there,
This isn't strictly arcade related, but my old, trusty 28" CRT TV (PAL) just lost all red colors. It's a 12-year old Prosonic (really cheap European brand, but their old CRTs were actually quite good).
I tried all forms of inputs available (pure antenna signal, Xbox, sat receiver etc.) and the problem remains.
Anyway, I thought that maybe some of the gurus in here could think of a few quick fix solution attempts before I ditch my TV :)   Like: where should I look for shorts or poor connections, which corroded plugs could cause the problem etc... I am open to replacing simple components, but ICs and the like are probably beyond my skills.
Any help is much appreciated, although my hopes aren't that high, hehe...
Kevin Mullins
    • Me on Myspace
Re: TV lost red colors
« Reply #1 on: January 18, 2010, 04:44:24 pm »
Open it up and take a good look around the neckboard attached to the tube.
SirPeale
  • Green Mountain Man
« Reply #2 on: January 18, 2010, 04:52:34 pm »
Could be a few things...bad neckboard transistor, back tube, bad video IC...I'd start simple and work your way to complicated.
Hamselv
« Reply #3 on: January 19, 2010, 05:09:22 am »
So when the R, G or B transistors are mentioned (in similar threads), this references three transistors on the neckboard (attached to the tube)?
If they are clearly labeled I will try swapping them around and see how the colors respond. Such an operation should be performed with the neckboard removed, right? As I recall (I haven't opened the TV yet) it should be possible to pull out the neckboard from the pins/socket at the narrow end of the tube...
Will it be necessary to discharge the tube? I have done that before, but won't bother/risk it if it isn't necessary  :P
Thanks for the help!
