Author Topic: When to prime?  (Read 5190 times)
Hawkweber
  • Last login:November 10, 2011, 09:21:50 pm
When to prime?
« on: January 16, 2010, 10:48:15 pm »
Working with MDF and will be priming it with oil-based primer/sealer but I was wondering if I should do this to each piece BEFORE assembling the parts (gluing them - will the primer interfere with adhesion) or if it is recommended to assemble it and then prime/seal?
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
Re: When to prime?
« Reply #1 on: January 16, 2010, 10:57:32 pm »
if you are planning on doing any detail work of different colours...it'd probably be best to do that before assembly...
otherwise it'll save you a lot of time to do it after assembly...
Hawkweber
Re: When to prime?
« Reply #2 on: January 17, 2010, 07:15:53 pm »
Nope - no fancy schmancy painting - just the basic semi-gloss black with some semi-gloss gold on the edges.
BTW - that Avatar of yours is wild.
Re: When to prime?
« Reply #3 on: January 18, 2010, 10:34:24 am »
You might want to re-think painting the edges, and go with a gold t-molding instead.
Hawkweber
Re: When to prime?
« Reply #4 on: January 19, 2010, 07:10:20 pm »
Well, it's for a portable arcade unit I'm building and in order to minimize weight I'm using 1/2" mdf.  I haven't seen 1/2" wide T-molding, and I don't really think there is enough edge showing to warrant it even if I could find it.
Re: When to prime?
« Reply #5 on: January 20, 2010, 08:15:45 am »
http://www.t-molding.com/store/product.php?productid=10&cat=25&page=1
White, but you could paint it gold.
SephYuyX
  • Last login:November 28, 2013, 11:40:04 am
  • I Am, Who I Am.
Re: When to prime?
« Reply #6 on: January 21, 2010, 06:08:54 pm »
Could also buy http://www.t-molding.com/store/product.php?productid=23&cat=12&page=1 if you think youre trimming skills are up to it.
Hawkweber
Re: When to prime?
« Reply #7 on: January 21, 2010, 10:59:53 pm »
Well, I had already designed, cut, and sanded the cab parts as if I wasn't going to use T-Molding (since I didn't know that 1/2" was available), so I guess it's moot now.  I'll keep it in mind for possible future cabs, though.
Thanks for all the info!
Re: When to prime?
« Reply #8 on: January 22, 2010, 08:05:51 am »
Just be careful with your cab, then.  MDF isn't very solid when it comes to the edges (easy to chip, or smash).
Blanka
Re: When to prime?
« Reply #9 on: January 22, 2010, 08:17:07 am »
Glueing always before priming!
And just 1 prime layer. Final layers are the ones to do more than 1 time.
