Author Topic: USB Controller Hack Project with pics..  (Read 1701 times)
supadave
  • Last login:June 11, 2023, 09:10:08 pm
« on: January 06, 2010, 09:00:58 am »
I got this idea from a thread from way back. You can read the thread if you like: http://forum.arcadecontrols.com/index.php?topic=84548.0
The controller I used is a $6.95 cheap pc controller that I got from RandyT's site. Groovy Game Gear: http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=65&products_id=258
And now some pics.. This project is not 100% just yet. Controller 1 is done. Tonight I will rig a test button and test all the connections. I went with Cat5 Cable and will wire my control panel the same. It will allow for easy removal or replacement down the road. Also I can color code my wires to the buttons and joysticks by using cat5.
This hack is just a cheaper alternative to an I-Pac and it lets you get a more creative feel when building.
supadave
Re: USB Controller Hack Project with pics..
« Reply #1 on: January 06, 2010, 06:29:21 pm »
Tested the controller and all inputs work perfect! I just loaded the windows controller map and crossed the inputs with the common ground wire and each one lit up fine. Next step is to make the second controller. This kind of work is what makes this hobby so fun..  ;D
« Reply #2 on: June 01, 2010, 07:29:36 pm »
I bought 2 of these about a year ago and screwed one up trying to solder wires to it.  I still haven't opened the second one.  Any tips on how you soldered it?  Any particular brand of solder or soldering gun, etc.
Any help would be great!
DeLuSioNaL29
bkenobi
« Reply #3 on: June 01, 2010, 10:59:42 pm »
Just don't keep the iron on anything for too long and you should be fine.  If you keep the hot iron on a chip or around a trace for too long, you will cook things and the chip will crack or the trace will lift.  Oh, and check to make sure you don't have bridged solder joints.  It's really not that difficult and fortunately not that expensive if you do screw things up.   :cheers:
syph007
« Reply #4 on: June 02, 2010, 09:17:39 am »
A flux pen also helps the solder stick to small via or traces.  That was what I found the easiest technique improvement anyway.
