Author Topic: WG 25k7107 chassis/Hantarex Monitor  (Read 1477 times)
MLew
  • Last login:May 10, 2018, 08:38:25 am
« on: December 23, 2009, 08:54:01 am »
Are these compatable?
I think the tube is bad in the WG monitor, and I don't know if I'm gonna mess with it, so I was gonna try to replace it with a Hantarex Polo 25 in monitor and just use the chassis of the WG....that is, if I is even possible. (Its an RCA tube on the polo if that matters)
grantspain
Re: WG 25k7107 chassis/Hantarex Monitor
« Reply #1 on: December 23, 2009, 09:38:06 am »
connectors are different but the chassis specs should match near enough,double check the impedence of both the vertical and horizontal yoke
