Author Topic: How to clean you cache on a modified XBOX  (Read 2387 times)
mike boss
« on: December 21, 2009, 05:07:38 pm »
Sorry guys, did a search here and found nothing.
I have an XBOX using slayers 2.7 I believe.
It boots up and right into XBOX media center.
I'm in the process of moving over MUGEN and it says I should clean the cache, I have no idea where to look or how to do it.
thanks
DJ_Izumi
  • Last login:September 26, 2026, 10:30:56 pm
Re: How to clean you cache on a modified XBOX
« Reply #1 on: December 21, 2009, 05:25:07 pm »
The Xbox has three 700mb partitions on the HDD that are used for game cacheing.  I've never had a problem with it but I guess some people have had unremovable files suck in it?  I forget the drive letters for those but honestly most dashboards by default prevent you from even accessing those partitions so you don't screw them up.  Honesty, I say run the game first and if it doesn't give you a problem, don't worry about it.
mike boss
« Reply #2 on: December 21, 2009, 05:37:05 pm »
Thanks, I'll give that a shot.
I'm in the process of moving over MUGEN now.
I thought prior I had seen an option to easily remove (clear) the cache from XBMC itself.
However looking now I see no such thing.
Reading about MUGEN it says clear the cache prior, but I will try without doing so and see what happens.
crashwg
« Reply #3 on: December 21, 2009, 05:39:51 pm »
The following directories can be emptied (delete all the files inside, not the directories themselves).
E:\\CACHE
X:\\
Y:\\
Z:\\
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
mike boss
« Reply #4 on: December 21, 2009, 08:33:12 pm »
Awesome !
Right now I am FTP'ing over mugen.
Can I simply remove the contents of these folders via the FTP program ?
(thanks!)
mike boss
« Reply #5 on: December 21, 2009, 11:20:34 pm »
Still moving over MUGEN.
For the most part everything moved over via FTP with the exception of about 300 files.
I logged off & then re-booted the XBOX.
I seem to recall doing so prior and when I re-loaded FILEZILLA the files that did not  transfer were showing.
WELL........... this time it didn't do that.
So I went to reinstall the entire MUGEN folder I thought it would give me the option to skip existing files. However it doesnt seem thats the case,
then entire folder is moving again. I assume its simply writing over the existing files ?
None the less fingers crossed I wanna make sure the entire folder moves.
I should get to MUGEN 2nite, same as FBAxxx.
Sorry guys I know off topic, not to do with the cache. (my bad!)
mike boss
« Reply #6 on: December 22, 2009, 03:41:58 pm »
thank, I deleted CACHE.
However it didn't help with MUGEN.
Back to the drawing board............well Google anyway !
