Author Topic: Monitor problem Mortal Kombat 2  (Read 2112 times)
Griip
  • Last login:December 22, 2009, 09:28:27 pm
« on: December 20, 2009, 03:32:27 pm »
Hello,
I am helping a friend with an MK2 machine, there is a huge colour distortion running through the middle as you hopefully can see in the pic, this was with it throwing out a blue monitor test
The only question I have is will a degauss help with this problem.
I know I am meant to have a monitor model when posting but I don't have access to the machine and was just checking if a degauss will be useful, before borrowing a wand.
grantspain
Re: Monitor problem Mortal Kombat 2
« Reply #1 on: December 20, 2009, 03:35:30 pm »
looks like a guassing issue to me
Kevin Mullins
    • Me on Myspace
« Reply #2 on: December 20, 2009, 05:23:52 pm »
Agreed.... definitely a degaussing issue.
Should do some degaussing automatically. I would check into why it's not first and then if need be manually degauss it.
grantspain
« Reply #3 on: December 20, 2009, 05:32:10 pm »
bet the ptc has shat out,unless of course its a manual degauss
Griip
« Reply #4 on: December 20, 2009, 05:45:10 pm »
Great, thanks for the replies, Ill take a look and see if I can see an automatic degausser and get the model number while I'm inside.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #5 on: December 25, 2009, 06:22:22 pm »
misalinged yoke/purity rings can cause the same symptom.
obviously , start with a simple manual deguass , and proceed pending results.
