Author Topic: Bios fiels showing in AtomicFe  (Read 2739 times)
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
« on: December 19, 2009, 08:48:50 pm »
How do I keep the bios files from showing in AtomicFe?  :dunno
Best of the Best of the Best. Sir!
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Bios fiels showing in AtomicFe
« Reply #1 on: December 20, 2009, 06:34:06 am »
2 solutions.
1) If you use your own gamelist, don't put your bios in the gamelist.
2) if you use automatic gamelist generation , use an Exclude list.
Point 6 of the tutorial...
http://www.atomicfe.com/EN2/doc/English/index.html
speedklz
« Reply #2 on: December 20, 2009, 09:43:55 pm »
The exclude list thats the ticket.. Thanks
speedklz
« Reply #3 on: December 25, 2009, 10:20:59 pm »
Can this file be built by hnad outside the studio?
youki
    • Atomic Front End
« Reply #4 on: December 26, 2009, 12:54:50 pm »
yes, of course, it is just a text file.
You easiest thing to do, is to create one with AtomicStudio to have the correct name and config done for you , then edit it with notepad for instance.
the file for exclude list is in the <atomicfe>/projects/<your project> folder and is named <your screen>.LIST.CFG.EXCLUDELIST
speedklz
« Reply #5 on: December 27, 2009, 05:11:11 pm »
I created an exclude file with the names of the bios file in a row with only return between them is this correct and where shoudl this file go If I am using atomicFe just as it came?
 Also I added the ambiance arcade sounds to it and it sounds great..
speedklz
« Reply #6 on: December 27, 2009, 07:22:06 pm »
I found it.. You put it under the projects main folder. now they dont show up.. Let me ask something else, why do a few of the snaps not show up, they do under mameui but not under AtomicFe?
youki
    • Atomic Front End
« Reply #7 on: December 29, 2009, 01:37:52 pm »
how did you name the file????...  It is not normal. it should be in your specific project folder and be named according to your screen .(and it works only if you have first created a excludelist from AtomicStudio (it activates it in your screen config file).
Which one for instance ? (give me the name of the rom and the name of the snap)
Could it be a "clone"?
speedklz
« Reply #8 on: January 02, 2010, 05:18:26 pm »
I named the file exclude.txt I then put it in the AtomicFe main folder and I went into the CFG fiel and told it to use the exclude list. :)
 Works like a charm. About the snaps, Ill have to look and see which ones, but there were 2 or 3 out of say 300 I have that the snap wont load, its like on some odd stuff lie sega`s Aladdian that has a rom name of affa or something. The snap loads in Mame but not in AtomicFe, let me say this these are jap version with odd rom names could that be it?
The CFG files are so easy to read that I have been able to fiddle with AtomicFe to make it fit my needs.. Thanks
youki
    • Atomic Front End
« Reply #9 on: January 02, 2010, 05:27:39 pm »
Ok, i understand better now.  you are modyfing the CFG file directly with a text editor.  ;)
But be aware if you do that you can have same mismatch if you use again AtomicStudio with that modified files..  AtomicStudio depends a lot on files naming convention. So don't be surprise if some strange behavior occurs.
For the snap problem, it is may be just because the clonelist is not up to date with your mame version.
Try to generate a new clonelist from your mame :
Code: [Select]
mame -listclones > clonelist.txt
then copy the resulting file clonelist.txt in your project folder (<atomicfe>/projects/<your project>) and also (just to be sure) in the <atomicfe>/metadata folder
speedklz
« Reply #10 on: January 10, 2010, 05:04:41 pm »
Ill try that.
speedklz
« Reply #11 on: January 17, 2010, 05:56:07 pm »
Hey Youki can I turn on the juke box mode by hand without going into the configurator?
youki
    • Atomic Front End
« Reply #12 on: January 18, 2010, 04:10:13 pm »
What you mean exactly?
Built'in jukebox in Atomic  need you create a "screen" for it , and put it somewhere in the hierarchy.
