Author Topic: unable to initialize DirectSound Mame32 0.36, windows 95 any ideas?  (Read 5863 times)
polaris
  • veni vidi congai
ive installed a soundcard and drivers which i thought was the issue, that all seems fine, still get the error message 'unable to initialize directsound' when trying to start a game. :(
any clues greatly welcome. cheers
Ginsu Victim
  • Comanche, OK -- USA
Re: unable to initialize DirectSound Mame32 0.36, windows 95 any ideas?
« Reply #1 on: November 30, 2009, 05:22:28 pm »
Got a win95 compatible version of DirectX installed?
polaris
  • veni vidi congai
« Reply #2 on: November 30, 2009, 06:26:22 pm »
cheers ginsu, probably not being as it didnt have a soundcard before, ill have a look
polaris
  • veni vidi congai
« Reply #3 on: November 30, 2009, 08:19:11 pm »
ok, there is a folder on the desktop called directx3 inside that folder is a setup icon amongst others, when i click on that i get a box within which one of the things it says is audio drivers-- no hardware support
theres a button marked reinstall direct x which gives an error if i click it, under that is a box (unclickable) saying restore sound drivers and below that a similar button for restoring video drivers which can be clicked and restores the drivers.
the sound card is working and drivers installed as far as windows is concerned. what am i missing?
gonzo90017
polaris
  • veni vidi congai
« Reply #5 on: December 01, 2009, 12:24:55 pm »
ok, ive gone into mame 32 options and set sound to no sound, and games launch so its working minus sound i now know.
removed directx3 via add/remove progs
loaded a cd of directx8 and windows said it was installed, it doesn't show up in add/remove programs and if i try to install it via add/remove it doesn't find the cd, where would i find the directx to see it is installed?
when i try to run mame with directx selected in the sound options it takes a little longer to get the error message than with directx3 ,like its trying but it fails
cheers all
Bobulus
  • Last login:July 11, 2014, 10:42:28 am
« Reply #6 on: December 01, 2009, 04:54:09 pm »
If you go to the Run menu and type
Code: [Select]
dxdiagwhat do you get?
