Author Topic: Zinc Help Please  (Read 1845 times)
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
Zinc Help Please
« on: July 19, 2003, 05:22:19 am »
i decided to load on zinc today, i got it running form mamewah all i did was made .bat files for each
game and pointed to them in mamewah.
d:\
cd
d:\Zinc
zinc.exe 1
im tired but its something like that but diffrent # for each game of coarse.
my question is...
is this a good way to run it? i tried the howards wrapper and i must be stupid i couldnt get it to work..
also can i set up individual controll settings for each game?
i tried make say for sfex2 set my keys for it and rename to sfex2.cfg and then in the bat i did..
d:\
cd\
d:\Zinc
zince.exe --use-controller-cfg-file=sfex2.cfg
zinc.exe 4
i did that in a bat file but it still uses the default controller.cfg setting...
anyone able to help me set this up correctly, or atleast get the controll thing going?
seems to be loading fine but if the bat file idea is bad in someway please let me know.
-thank you
Syxx
  • Bling Bling
Re:Zinc Help Please
« Reply #1 on: July 19, 2003, 05:24:00 am »
oh and what should i change in the settings to get the best FPS, it seems to get good fps so far but whats some good settings to use?
im using a 1.3ghz, gf3ti200, 386megs ram system, win98
just currious if you have time to add also which games are emulated to run fine and have sound, and which run but with no sound
thanks again =)
« Last Edit: July 19, 2003, 05:25:52 am by Syxx »
waveryder
  • Last login:July 14, 2011, 04:26:17 am
  • I Troop, therefore I am
    • BubbleGum Custom Art
Re:Zinc Help Please
« Reply #2 on: July 19, 2003, 06:06:59 am »
Set Zinc up useing zincfe gui first! This will make all the neccessary *.cfg files for zinc for you. Then just run "zinc.exe #" from mamewah without the cmd switches youve put in the *.bat files or use this method http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=9513
                                            Later
When pixelated clipart just wont do, just call for Betty
Syxx
  • Bling Bling
Re:Zinc Help Please
« Reply #3 on: July 19, 2003, 11:09:37 pm »
so i take it that this fe sets up all the controller per game? or is the controller settings universal for all games?
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
Re:Zinc Help Please
« Reply #4 on: July 20, 2003, 12:39:39 am »
u can do both
It's all about the Pentiums
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Zinc Help Please
« Reply #5 on: July 20, 2003, 01:34:17 am »
Look for a past post of mine, I showed my wrapper config.  For me the wrapper pretty much worked as was.
