Author Topic: Zimmy's Jukebox - The Rise & Fall  (Read 13575 times)
zimmy
  • Last login:March 17, 2011, 01:28:37 am
« on: November 05, 2009, 12:42:37 am »
I'd been planning on building a digital jukebox for a while and finally got around to it. Once I had it all built I hired it out for about 8 months and made a fair bit of cash from it.. Then this week there was what is now known as.. "The Incident"...Pictures and details below:
« Last Edit: November 05, 2009, 05:07:31 pm by zimmy »
zimmy
Re: Zimmy's Jukebox - The Rise & Fall
« Reply #1 on: November 05, 2009, 05:06:32 pm »
Cut out my two side pieces from MDF sheets. Spaced them apart to get an idea of how wide I wanted it. Measured this then cut my bottom bit to this lenth.
Attached the bottom piece. Now have an idea of width, how it will look etc. All pieces are attached from the inside using L-Brackets.
« Last Edit: November 05, 2009, 05:11:45 pm by zimmy »
zimmy
« Reply #2 on: November 05, 2009, 05:18:53 pm »
Cut and attached a few more pieces. At the back I have made a lower back piece and upper back piece, leaving a gap in the middle for a piece I will put on hinges and use as a maintenance door.
zimmy
« Reply #3 on: November 05, 2009, 05:23:37 pm »
The Box with the maintenance door on the back.
Front View
zimmy
« Reply #4 on: November 05, 2009, 05:27:59 pm »
Installed the chasing lights which will go to the beat of the music
zimmy
« Reply #5 on: November 05, 2009, 05:30:30 pm »
Laid out the parts to about where they will go on the face piece. (Not actual speakers that will be going in).
The screen and Perspex in the face play which will be later attached to the rest of the jukebox.
zimmy
« Reply #6 on: November 05, 2009, 05:33:12 pm »
Face piece with speakers holes cut, some button holes cut and lights and screen perspex in.
zimmy
« Reply #7 on: November 05, 2009, 05:36:05 pm »
The 15” Speakers which I will disassemble and install in the jukebox. The Woofers were originally going to go in the front down the bottom but wouldn’t fit so I ended up putting them in the sides and the tweeters on the front face piece, 3 down each side of the screen.
zimmy
« Reply #8 on: November 05, 2009, 05:38:20 pm »
Face piece with the screen and buttons in. I painted a bit of the bottom just to see how it was going to look..nearly ready to be attached.
zimmy
« Reply #9 on: November 05, 2009, 05:41:08 pm »
A close up of the buttons. They will be used as next page, previous page (arrows) and the red buttons are the numbers 0 to 10 to select the song using SK Jukebox. They are wired in using an iPac keyboard encoder.
zimmy
« Reply #10 on: November 05, 2009, 05:41:59 pm »
The back of the face plate. The buttons are not yet wired into the iPac.
zimmy
« Reply #11 on: November 05, 2009, 05:43:08 pm »
Close up of the iPac
Wiring the buttons
zimmy
« Reply #12 on: November 05, 2009, 05:44:23 pm »
The first Doofer disassembled and screwed into the side of the box.
zimmy
« Reply #13 on: November 05, 2009, 05:45:47 pm »
Outside view
zimmy
« Reply #14 on: November 05, 2009, 05:46:37 pm »
Front view
zimmy
« Reply #15 on: November 05, 2009, 05:49:20 pm »
The maintenance door on, computer and amp in and screwed to the base. I also screwed on wheels to the bottom to make it easier to move which I don’t have a pic of.
zimmy
« Reply #16 on: November 05, 2009, 05:51:17 pm »
Top view of this
zimmy
« Reply #17 on: November 05, 2009, 05:51:53 pm »
Started painting the front
zimmy
« Reply #18 on: November 05, 2009, 05:53:36 pm »
Face plate attached
zimmy
« Reply #19 on: November 05, 2009, 05:55:07 pm »
Up and running just needs paint job
zimmy
« Reply #20 on: November 05, 2009, 05:56:39 pm »
Finished product with paint and all. Sounds great!!!
zimmy
« Reply #21 on: November 05, 2009, 05:57:22 pm »
zimmy
« Reply #22 on: November 05, 2009, 05:58:08 pm »
zimmy
« Reply #23 on: November 05, 2009, 05:59:17 pm »
zimmy
« Reply #24 on: November 05, 2009, 06:00:00 pm »
Then there was "the incident".. The one tip which I don’t think is mentioned enough or at all on this forum is..When moving your jukebox, make sure you strap it on to the trailer tight enough so that it doesn’t bounce out on the highway and scatter into a hundred pieces!!!
zimmy
« Reply #25 on: November 05, 2009, 06:00:17 pm »
But..what can ya do? Currently working on a new one. Touchscreen and a much more mobile design which can travel in the back seat of the car!
Interstate90
  • Last login:December 24, 2009, 01:49:00 pm
« Reply #26 on: November 05, 2009, 06:07:50 pm »
Ouch.
Good luck on your next build I guess. And be sure to strap it down this time  ;)
« Reply #27 on: November 05, 2009, 06:16:02 pm »
Ow.
Was any of it salvageable?
that stinks. But, you'll likely build it even better next time, so, live and learn.
zimmy
« Reply #28 on: November 05, 2009, 07:56:15 pm »
Yeah a lot of it was salvagable and other parts which I thought were, only worked for a short period of time.. Like the lights which I thought were fine, didnt even blow a globe. I plugged it in they all went fine for about 30 seconds then one blew.. Only a globe though, worth about 5 bucks. And the computer started up and worked for about 5 minutes then the power supply blew (also easily replacable). But the rest of the main parts, other than the box itself and perspex were still good..amp, speakers, keyboard encoder etc. So not too worried. I planned on building another one anyway, this just gives me a bit of motivation to do it.
zimmy
« Reply #29 on: November 05, 2009, 08:01:38 pm »
Ouch.
Yeah thanks, next one is already looking better. I had taken the last one to many places with it strapped down the exact same way but this time it was a fairly long drive on a bumpy road and over time the top strap slowly slipped and loosened until it was nothing but a pile of firewood on the side of the road. haha.
