Author Topic: Showcase cab w/Hantarex Polo 1 33" monitor (dead monitor) - alternative monitor?  (Read 2550 times)
eastbayarb
  • Last login:March 08, 2013, 12:15:06 pm
I have a Showcase cabinet that has a Hantarex Polo 1 33" monitor. The monitor is dead (doesn't turn on). Can someone recommend an alternative monitor for this cab? Perhaps a monitor that I can keep in the case?
thanks
Jack Burton
It doesn't turn on?  Have you decided that you do not want to repair this monitor?  I think you should do a little more troubleshooting before giving up.
But If that is the case then there are a few options available.
The equivalent of a 33" arcade monitor is a 32" televison.  It might be possible to fit a 32" CRT in there with some modification to the cab.
A 27/29" monitor or TV would have much better chance of fitting.  It should just set on a shelf in the space where the old monitor was.
If you are into new games you might consider a wide-screen LCD as a replacement.
You will have to devise a new bezel to cover up the empty space around the screen.
eastbayarb
I researched it about a year or so ago and a guy said I need to replace the bu508a or bu508af transistors. This is beyond my technical skills, hence this post. I really don't want to put an LCD monitor in here. Old school games look horrible on those
Jack Burton
I think the best option is just to go with a replacement 33" arcade monitor then.
It's the least work and the best solution.  The only downside is cost.
I've never heard anything bad about Nieman displays.  They make a CGA monitor that will fit your cab:
http://niemandisplays.com/nieman_video_displays_009.htm
Wells Gardner makes 33" D9200 and D9400 monitors.
I have also heard there is a Kortek 33" monitor.  You might try looking for that.
« Last Edit: October 29, 2009, 10:41:11 pm by Jack Burton »
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Yes we still have about 40 tubes to do the 32" CGA arcade monitor.
I would be happy to help if you are intersted.
Thx
Rick Nieman
Rick@niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
