Author Topic: Suzo Happ Vision Pro 19" LCD CGA/EGA Game Display  (Read 4979 times)
Swatwolf
  • Last login:April 18, 2020, 02:27:44 am
« on: October 09, 2009, 06:15:31 pm »
Does anyone have experience with these monitors?  I was thinking of buying one to replace my APB Medium Resolution monitor but I am unsure if it would work or not, any ideas? :burgerking:
Video Games Currently owned and running: Mania Challenge, X-Men (Children of the Atom), A.P.B.
In the works Mame Trek (Scratch Built), Donkey Kong Jr. (Just got a PCB for)
Ken Layton
  • Guru
  • Technician
Re: Suzo Happ Vision Pro 19" LCD CGA/EGA Game Display
« Reply #1 on: October 09, 2009, 08:14:13 pm »
Those things are expensive. You have to buy the special mounting brackets so it can directly replace your existing monitor. Plus add on Happs' shipping charges, taxes, and handling charges.
sarge
  • Last login:April 27, 2015, 01:42:54 pm
« Reply #2 on: October 10, 2009, 01:08:07 pm »
You can just use the frame of the CRT you have in your cab now.  I've had no problems with the ones my company has purchased.
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #3 on: October 10, 2009, 04:08:32 pm »
The trick with these LCD's is how many of the old standard res and mid res games do they really accept??
I have tested many of these and most of them only accept about 60% of the games... for example if they are above 15.8Khz Horizontal rate you get an out of range message.
We have developed with our partner in Taiwan a family of LCD's that has accepted every game I have thrown at it.
They have the ability to do a broader range of adjustments to size and position in the event the "auto adjust" is not perfect, and remembers them.
We use the same A/D board (analogue to digital) in all sizes ranging from 10" all the way through to 42" (47" is coming).
This allows us to stock these boards, which is important as the A/D board is the most common failure in any LCD.
We are in the midst of developing a system that will allow us to create a custom size bezel for virtually any cabinet. We will stock oversized metal plates and when you call and tell us your opening size, we will cut the plate to size. We are in the process of sourcing a metal shear to do this.
If you are after just the LCD, e-mail me and I will give you a quote.
Thanks as always
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
