Author Topic: Making inside angle (concave) cuts  (Read 2983 times)
Nogginboink
  • Last login:December 21, 2014, 10:16:45 am
« on: October 07, 2009, 11:44:02 am »
When cutting sheet material (MDF/plywood), what's the best way to cut to get an inside angle?
I realize I could radius the cut (and I might end up doing that) but was wondering how y'all have done this on your cabs.
Blanka
Re: Making inside angle (concave) cuts
« Reply #1 on: October 07, 2009, 03:59:35 pm »
Just go to say 2cm off the corner with the circular saw. Then do the last part with...... the mighty HAND-saw!
If you want a radius, just make a round hole with a spade bit or circular saw first at the right place, then saw. In that case the hand saw can be handy for the last bit as well.
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #2 on: October 08, 2009, 10:06:27 am »
a good jigsaw works well for this application...
Kman-Sweden
  • Up the Irons!
« Reply #3 on: October 08, 2009, 10:34:42 am »
Man, I need pictures to follow this.  ???
 :blowup:
Still didn't get it.
