Author Topic: Wells Garner 25k7401 part help...  (Read 2424 times)
DynamiteSJ
  • Last login:July 15, 2011, 12:17:23 pm
« on: October 06, 2009, 08:25:11 pm »
Hi..
I was doing a cap kit and flyback on my WG 25k7401 and when i was inspecting my main board i found that L703 is broken.  I've done some research on it and what i found is:
TRANSFORMER
Designation  -  Description - Part No.
L703 - COIL PINCUSHION CORRECTION - 009A2970-002
Where can i purchase on of these at? Also, is there a method of installing it? (There is an adjust on it)
Thanks,
Dave
Kevin Mullins
    • Me on Myspace
Re: Wells Garner 25k7401 part help...
« Reply #1 on: October 06, 2009, 09:42:41 pm »
Honestly, most coils like those that I have seen "broken" were merely just the base on which it stands is what got broke or knocked loose. (I've super glued several back together)
The ferrite core and the wire winding are whats important.
How exactly is yours "broken" ?
And I have about a gazillion of those if you find yourself really needing one.
(ok, maybe not a gazillion, but close)
DynamiteSJ
« Reply #2 on: October 06, 2009, 11:41:57 pm »
its definitely broken.. its swinging around like a slinky... and its all brittle with plastic pieces breaking off from the center
Kevin Mullins
    • Me on Myspace
« Reply #3 on: October 07, 2009, 12:12:28 am »
Yeah, if they're solid and broken like that I'd say glue it...... but if it's brittle then it's pointless.
If you need one PM me your info.   ;)
DynamiteSJ
« Reply #4 on: October 07, 2009, 12:26:38 am »
i already desoldered it and it pretty much fell apart
DynamiteSJ
« Reply #5 on: October 07, 2009, 12:53:14 am »
Ken Layton
  • Guru
  • Technician
« Reply #6 on: October 08, 2009, 10:40:46 am »
You can order that from the parts department at Wells-Gardner.
Kevin Mullins
    • Me on Myspace
« Reply #7 on: October 08, 2009, 05:35:01 pm »
Happ carries them too according to their site, but bleah ....  :P
Part # 49-1751-00
I just sent him one.
I happen to have more of those chassis laying around than I will ever get put back together.
