Author Topic: Mamewah step by step please ?  (Read 1414 times)
JamieDeb
  • Last login:August 25, 2004, 07:03:22 pm
« on: July 16, 2003, 11:38:21 am »
I just downloaded "Mamewah v0.95b"
Then unzipped "mame071b_i686.zip" to "C:\EMULATOR\Mame71" directory.
The roms are in the "rom" folder, same directory.
The snaps are in the "snap" folder, same directory.
I have edited the "EMU1.CFG" like this:
Emulator Executable = C:\EMULATOR\Mame71\mamepp.exe
Default Options =
Extra Options #1 =
Extra Options #2 =
Show DOS Box = 0
Send ROM Path = False
Use Long Filenames = True
Send ROM Extension = False
DAT Filename =
NMS Filename =
CatVer Filename =
ROM Path =
ROM Extension = ZIP
List Generation Method = 2
...but nothing displayed...what am I missing please (except from intelligence perhaps ?)
Thnaks a lot,
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
Re:Mamewah step by step please ?
« Reply #1 on: July 16, 2003, 12:36:34 pm »
Not flaming you here, but please take about 5 minutes and read the accompanying readme that comes with the program.....  I set this up yesterday for the first time, had a little bit of trouble, and lo and behold upon reading further it tells you how to set it up.  Within 15 minutes I had it set up, with a new skin even.
Just looking at your file, you have no path to your roms, dat, or catver for starters....
Jeehemdee
« Reply #2 on: July 16, 2003, 01:33:50 pm »
You're right about reading the manual...but from the read me file it's said:
'ROM Path' :  specifies the location for the emulators ROM's (used when refreshing games list / running game).
(NON-M.A.M.E. ONLY)
So is it necessary for Mame (NON-M.A.M.E. ONLY) ?
« Last Edit: July 16, 2003, 01:36:24 pm by Jeehemdee »
« Reply #3 on: July 16, 2003, 06:41:42 pm »
This is one part where the readme is out of date, sorry.  You now have to state the ROM path for all emulators, since I treat all the same now.
Add the ROM path and you should be all set.  Use Long Filenames could be set to False too, but I don't think it matters in this case.
Apollo
    • Eight Bells
« Reply #4 on: July 17, 2003, 02:43:34 am »
Well I just downloaded version 0.90 and there isn't even a ROM path option??? What do I do?
« Reply #5 on: July 17, 2003, 08:12:53 am »
See the thread you started
