Author Topic: weyia 826  (Read 2761 times)
alienware32
  • Last login:September 26, 2009, 05:28:40 pm
weyia 826
« on: September 17, 2009, 12:37:33 pm »
i have a weyia 826  all is working except the brightness pot on the remote board any ideas what wrong with it
Kevin Mullins
    • Me on Myspace
Re: weyia 826
« Reply #1 on: September 17, 2009, 02:03:33 pm »
Is it TOO bright ?
alienware32
Re: weyia 826
« Reply #2 on: September 17, 2009, 02:22:00 pm »
yes i can only adjust it with the flyback
Kevin Mullins
    • Me on Myspace
Re: weyia 826
« Reply #3 on: September 17, 2009, 02:42:25 pm »
So if you turn the flyback down.... the brightness pot makes no changes still ?
(if you overdrive it with the flyback, you'll never see a change)
Is there a contrast pot ? Is it cranked up ?
Starting to sound like you have a bad pot.... just trying to verify or at least narrow it down.
alienware32
Re: weyia 826
« Reply #4 on: September 17, 2009, 02:46:25 pm »
no change at all and theres no contrast control
Kevin Mullins
    • Me on Myspace
Re: weyia 826
« Reply #5 on: September 17, 2009, 02:57:31 pm »
Measure the resistance on the pot itself.
1       2
     3
1+2 gives overall value of the pot.
1+3 or 2+3 should vary from overall value down to zero when adjusting pot.
Best to remove the pot for testing.
« Last Edit: September 17, 2009, 02:59:21 pm by Kevin Mullins »
alienware32
Re: weyia 826
« Reply #6 on: September 17, 2009, 02:59:33 pm »
how do i measure it
Kevin Mullins
    • Me on Myspace
Re: weyia 826
« Reply #7 on: September 17, 2009, 03:25:46 pm »
alienware32
Re: weyia 826
« Reply #8 on: September 17, 2009, 03:52:26 pm »
i measured it the pot is fine i think it something on the chassis
Kevin Mullins
    • Me on Myspace
Re: weyia 826
« Reply #9 on: September 17, 2009, 08:06:42 pm »
So is the value on that pot ?
alienware32
Re: weyia 826
« Reply #10 on: September 17, 2009, 08:44:43 pm »
i think it the chassis the pot value is fine
Kevin Mullins
    • Me on Myspace
Re: weyia 826
« Reply #11 on: September 17, 2009, 09:21:55 pm »
I was going to compare your readings against what it should be......
Do you have a schematic or manual for that chassis ?
alienware32
Re: weyia 826
« Reply #12 on: September 17, 2009, 09:56:54 pm »
no schematic it a 826 from 8 liners
