Author Topic: Will sanwa 27 29PF31 fit in simpson cabinent?  (Read 3005 times)
codenamed
  • Last login:January 06, 2012, 12:46:04 pm
« on: September 06, 2009, 08:18:34 pm »
gokun
  • Last login:March 26, 2014, 04:57:18 pm
Re: Will sanwa 27 29PF31 fit in simpson cabinent?
« Reply #1 on: September 09, 2009, 05:00:47 pm »
well i can't answer your question directly but i can tell you i put one of those in my tekken cab and it was a PAIN...
the holes didn't quite line up and the support it was in wasn't quite the same so ended up having to cut and modify inside of my cab to accomodate it...took forever...anyways, just my experience with one of those ;)
hatrick
  • Last login:January 23, 2020, 12:47:20 pm
  • Big Brother is Watching You!
« Reply #2 on: September 09, 2009, 05:13:53 pm »
I don't think it will. I have an old TMNT 4 player cab, and the same monitor. I was planning to put the Sanwa monitor in it, but it is too deep and would stick out the back. I also have a converted Simpsons cab that appears to be a little deeper, but I'm still not sure it would fit. If I get the opportunity, I'll measure the Simpson's cab and give a more concrete answer.
codenamed
« Reply #3 on: September 11, 2009, 05:14:06 pm »
Looks like its going to fit barely going to have to remove the speaker mount to place it in and drill new holes but it should fit now I need help wiring it.
gokun
« Reply #4 on: September 12, 2009, 03:44:13 am »
Ok, let's test my memory....it's the like 10 pin plug right(the big white square one)?
If so, I believe it's:
STD/SANYO
Red=Red
Green=Green
Blue=White
Sync=Yellow
Ground=Black
then
Power=Thick White
Ground=Thick Black
Earth=Yellow w/Green Stripe
but my memory is a bit hazy so maybe wanna double check that first hehehe pretty sure that's it though
codenamed
« Reply #5 on: September 12, 2009, 09:09:05 am »
STD/SANYO
Red=Red
Green=Green
Blue=White
Sync=Yellow
Ground=Black
then
Power=Thick White
Ground=Thick Black
Yes its a big square white plug. Going to attempt to mount it today if I can get someone to come over and help.
