Author Topic: New WG9800 problem  (Read 3327 times)
Hogie1418
  • Last login:October 23, 2013, 04:06:39 am
New WG9800 problem
« on: September 02, 2009, 06:43:32 am »
Well I just got my new monitor installed and right out of the box there was an issue. In the upper left hand corner there is a reddish hugh that is there all the time when the monitor is on. The only exception is when there is a black screen. Is this something that I can fix or did Wells send me a piece of ---steaming pile of meadow muffin---?
grantspain
Re: New WG9800 problem
« Reply #1 on: September 02, 2009, 04:54:14 pm »
have you tried to access the degauss on the on screen menu?
Hogie1418
« Reply #2 on: September 02, 2009, 05:26:47 pm »
nope but I will go try that!! ;D
Hogie1418
« Reply #3 on: September 04, 2009, 03:32:39 am »
alright well I found out how to degaus the monitor(took me awhile) and now the colors are in different places than before. Before it was just redness in the upper left hand corner. Now there is green in the upper right hand corner and a slight bit of red in the bottom left but the original red disapeared. Do I keep doing this until it get it right or is there something else wrong?
Ummon
  • Trade Count: (+13)
« Reply #4 on: September 04, 2009, 03:42:20 am »
Could be the monitor's direction. I've seen a 45-degree lateral rotation fix this. Not the best news, but there it is.
Yo. Chocolate.
Stephen Hawking
grantspain
« Reply #5 on: September 04, 2009, 04:33:48 am »
if you have a seperate degauss switch hold it down until it clears the problem-about 5 seconds
Hogie1418
« Reply #6 on: September 04, 2009, 05:15:32 am »
what do you mean separate degauss switch? By rotating it lateraly wouldnt just turning the entire cabinet in a different direction do this? I dont quite understand how this would help. Maybe I dont know the deffiniton of lateral  :P
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #7 on: September 05, 2009, 09:01:35 pm »
a crt using electromagnetic deflection is sensitive to external magnetic fields .
to illustrate this . turn any operating crt tv on its side. observe pic . return to normal position , observe pic
the effect  is caused by interaction with planetary magnetic field .
if the crt has encountered a stray field of sufficient strength,  a manual deguassing may be required to neutralize the effect
Ummon
« Reply #8 on: September 06, 2009, 01:12:22 am »
Monitor, cab - same thing. Hadn't seen it till recently, but a while ago saw it described here as the monitor being affected by the Earth's magnetic lines of force.
Yo. Chocolate.
Stephen Hawking
gatordad
  • Trade Count: (+11)
  • Last login:Yesterday at 07:03:33 pm
« Reply #9 on: September 06, 2009, 09:02:05 am »
Definately sound like  interference of some kind
how close and where is your speaker / speakers mounted in relation to the monitor.
Could be the magnet causing the issues you describe.
Remove the speaker completely and try to degauss again, see what it does.
also what was mention already might work as well. lateral means  if the cab is facing south, turn it so it faces west and see what happens.
Hogie1418
« Reply #10 on: December 16, 2009, 10:31:33 pm »
Alright, well I just finished up all of my finals and I am back at home to try and resolve this monitor problem. I rotated the cabinet 270 degrees and all of the red and green nearly disappeared as I was rotating it. The green is completely gone but there is still a small red line down the left hand side. When I rotate the cabinet slightly to the left more red shows up, and when I rotate it to the right green starts to show. Is there any way to make this rotation permanent without leaving the cabinet facing in this direction?
I am going to go remove the speakers as well and try it again but since rotating it seemed to do the trick I figured the speakers were not the problem.
grantspain
« Reply #11 on: December 17, 2009, 03:19:00 am »
manual degauss wand required me thinks
Hogie1418
« Reply #12 on: December 18, 2009, 03:28:03 pm »
Manual Degauss Wand.?.? How does one obtain one of these?
grantspain
« Reply #13 on: December 18, 2009, 03:55:38 pm »
ebay
Hogie1418
« Reply #14 on: December 18, 2009, 05:26:20 pm »
grantspain
« Reply #15 on: December 18, 2009, 05:28:31 pm »
yep that should do the job,it cannot damage your monitor
Hogie1418
« Reply #16 on: December 18, 2009, 05:59:00 pm »
Nice, Thanks for the help Grant! Im going to go order one of these right now. Fingers are crossed in hopes that this will fix the problem.
