Author Topic: bl27cb0p (Billabs 1024x768 capable arcade monitor) = No longer available?  (Read 2281 times)
metahacker
  • Last login:January 17, 2024, 03:09:39 am
so, am I right in thinking that the Billabs BL27CB0P is no longer available?
i.e. the one with these specs
27" 15~48 kHz VeriFlat™
Autosync™
CGA/EGA/VGA/SVGA/XGA Penta-Resolution
V-Freq. 47~90 Hz
Adjustment Controls: Brightness, Contrast, V-Pos., V-Size,V-Hold, H-Hold, H-Position, Pincushion, H-Size, Trapezoid, Rotation, RGB Adj., Impedance Select Switch
Sync: 15-pin D-sub male connector and/or 6-pin(R, G, B, GND, H+V, V) connector
I tried looking into Wei-Ya's models since they were the OEM.  and i dont think i see anything comparable?
The only tri-sync Wei-Ya's I see are 640x480.
Is there anything comparable still on the market?  i.e. 15khz arcade monitor that also runs 1024x768 and has a Dsub connector.
I see that there is a Betson 800x600 but nothing 1024x768....??
grantspain
you have no chance with a crt monitor at those specs-you're only chance is a lcd now
Ummon
  • Trade Count: (+13)
Short answer is yes. No longer made.
Yo. Chocolate.
Stephen Hawking
Gamester
Yep, it's long gone.  I wish I had purchased one of these a couple years ago when I had the chance.  Now I'm stuck with the decision of whether to go for a low res multisync (cga/ega/vga) or a high res (SVGA/XGA).  It's a very hard decision, which would be infinitely easier if I could actually see them both.  I have no idea what the classics would look like upscaled on the high res arcade monitor, but I do know it would be nice to have that flexibility for other things (Pinball, PC games).
ahofle
    • Arcade Ambience Project
There is also a middle ground: the WG9800 (CGA/EGA/VGA/SVGA).  It also supports XGA (1024x768) in interlaced mode with Soft15khz.  Works great for PC games that need a little more resolution.  In fact, any monitor that supports EGA modes should support interlaced XGA.  There is a bit of flickering in windows, but games look nice and smooth.
