Author Topic: Needing help with repair or replacment happy to pay  (Read 2503 times)
PCMedics
  • Last login:September 22, 2013, 12:28:12 am
« on: August 01, 2009, 02:34:06 pm »
1st off sorry for the cross post also put this in wanted to buy or sell. I have just gotten nice Ms. Pac-man dead display but machine plays takes coins starts and you can hear the machine work when you hit player one or two. :) I would like to hire someone to replace or repair the display. I can provide a good place to work on it in our computer store and will pay fairly. I tried the local tv shops here they do not work on arcade machines but this is a smaller college town . I will if i have to attempt to replace it my self but I am a PC tech and not fond of working on monitors. I am in Boone NC northwest corner of the state near the TN and KY borders about 2 hours from Charlotte. If i can not find a person to do this, does any one have a link to a detailed tutorial on replacing the monitor i have not found any online for MsPacman yet. Thanks Tom
Kevin Mullins
    • Me on Myspace
Re: Needing help with repair or replacment happy to pay
« Reply #1 on: August 01, 2009, 05:04:06 pm »
You still not willing to pull the chassis ?
The trouble you will have is finding anyone local to ya.
(I'm damn sure not)
I'm betting it has a K4600 or G07 monitor in it, which are very commonly repaired.
You would have to at least truly identify it. (make/model) That would help as some people are more familiar with certain ones.
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #2 on: August 01, 2009, 05:13:59 pm »
If you get to the point you want to replace the display... you may want to try our 19" CGA LCD.
I did a retro for a local here and the mounting was very simple. Turns out if you leave the original monitor brackets in the cabinet they are 3 and 3/4' from the glass.
Perfect size for a 2X4. 2 pcs a few screws and pretty much done.
Other wise good luck!
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
PCMedics
« Reply #3 on: August 01, 2009, 06:47:16 pm »
Happy to take pictures and provide any info on the monitor in there if that helps get a recommendation  on how to replace it . I will not be repairing the display myself. I prefer to pay someone familiar with the display to repair or replace it . What info or pictures would be the most helpful?
Kevin Mullins
    • Me on Myspace
« Reply #4 on: August 02, 2009, 01:33:25 am »
A decent pic of the main chassis will probably be enough to generally identify it.
(the bigger circuit board on the monitor frame)
PCMedics
« Reply #5 on: August 02, 2009, 12:15:20 pm »
Here are some pictures I took of the monitor inside the machine please let me know if you need more or of any specific area. Thanks Tom
Kevin Mullins
    • Me on Myspace
« Reply #6 on: August 02, 2009, 02:03:23 pm »
It's an Eletrohome G07-CBO.
Very common monitor.
Worst case scenario..... capacitors, a couple transistors, flyback.
PCMedics
« Reply #7 on: August 02, 2009, 03:36:47 pm »
Well now I know what one it is. Now the hard part to find one to buy and someone to install it. If it comes discharged I could do the install I guess not that keen working on the one that's in it. I did post it in the help wanted in the local craigslist maybe I will get lucky and find a unemployed tv repair person :)
SirPeale
  • Green Mountain Man
« Reply #8 on: August 02, 2009, 04:34:36 pm »
If you can remove the chassis from the tube, I can repair it for you.  It's fairly straightforward.
PCMedics
« Reply #9 on: August 02, 2009, 04:54:59 pm »
Is it cost effective to ship it to you and back I do see some burn in on it also when it is off? Thanks Tom
SirPeale
« Reply #10 on: August 02, 2009, 06:04:21 pm »
I can't fix burn - only a replacement tube will fix that.
I haven't priced shipping a chassis lately, but can get you an estimate if you give me your ZIP code.
PCMedics
« Reply #11 on: August 02, 2009, 08:01:53 pm »
Sure it is 28607
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #12 on: August 02, 2009, 10:33:33 pm »
not to step too hard on SirPeale's toes,  should shipping prove to be too high, i know of a fellow tv tech in Shelby...
PCMedics
« Reply #13 on: August 03, 2009, 09:31:14 am »
Great if someone from Shelby wants to do the job if shipping is prohibitive to SirPeale, I would be more then happy to pay them to come do it.
