Author Topic: still having trouble finding any 33e 1/2w carbon resistors for hantarex 9000  (Read 2458 times)
arcade1213
  • Last login:July 27, 2009, 12:08:27 pm
checked digikey they dont have it and neither does mouser.does anyone know where i could buy these or will a different type work like metal film or metal oxide film resistors.
thanks for your time
Kevin Mullins
    • Me on Myspace
arcade1213
Is the 33ohm the same as 33e.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
when in doubt on resistance values , one can reference the pcb designation to the schematic  ;)
as much as i detest rat shaft ( radio shack) , they do list a 33 ohm 1/2 w standard carbon resistor
http://www.radioshack.com/search/index.jsp?kwCatId=&kw=33%20ohm%20resistors&origkw=33%20ohm%20resistors&sr=1
and a 330 ohm
http://www.radioshack.com/product/index.jsp?productId=2062319
Kevin Mullins
    • Me on Myspace
Schematic just says 33 ....... parts list says 33E.
But all the resistors in the parts list are designated with the "E" aside from the particular "K" resistors which match the schematic. Such as 2K, 10K, 20K, etc.
So my best assumption would be that 33e is nothing more than a 33Ohm resistor.
(1/2 watt, 5% tolerance and all that of course)
arcade1213
Awsome thanks
