Author Topic: Designing a Router for Design School, need opinions from woodworkers.  (Read 2529 times)
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
Hey guys,
I've been around periodically, I'm a design student at UC and we're working on a power tool this quarter. I decided to do a router, snagged a cheapie craftsman off craigslist to dissect. I need you woodworkers (I figure you guys use routers plenty when working on your cabs and all that) to chime in.
Here's what I'm going for. A fixed base router, around 2 - 2.25 HP, I want it to be fairly light and nimble with a low center of gravity and high visibility. What other features/design elements would you guys be interested in seeing applied to a router?
Thanks guys. I'll keep this thread updated with drawings and renders.
I had to beat them to death with their own shoes...
fixedpigs
  • Last login:Yesterday at 01:02:44 pm
  • warning: drew can't handle my avatar...
Hey guys,
a power cord that plugs in at the top...out of the way...
a power switch that can be flicked on & off without taking the hands off the base...
Encryptor
  • Trade Count: (+34)
1/4" & 1/2" collets.
Encryptor
Xiaou2
  • Last login:June 11, 2025, 11:55:17 pm
  • NOM NOM NOM
 High Visibility?
 How about a positionable mini camera that pipes a picture of the cutting blade
and surface to a small LCD panel mounted on top of the router.
 Would need dust attachment or use the power of the motor to add a mini-dust
collector unit.  (or simply blasts air from the motor to the base and clears out dust
in all directions)
 LEDs to light the surface area.
 Grid-lines that can be overlayed on the LCD panel, so can use to match up
to hand cut drawn lines as you route.  OR - the overlay could simply be a
clear-plastic printed overlay that rests on top of the LCD.
Shortbus
Re: Designing a Router for Design School, need opinions from woodworkers.
« Reply #4 on: November 01, 2009, 09:52:58 am »
I agree with all of the above. especially being able to turn off without letting go, and power cord on top. The camera idea is awesome as well, boy i'd like that feature for sure.
if you need a 'tester' for what you come up with, let me know I'll send you my address. I use a router weekly....
UFO8MyCow
  • Last login:February 12, 2024, 12:26:27 pm
« Reply #5 on: December 23, 2009, 03:56:14 am »
how about an offset belt drive motor. I have access to a porter cable laminate trimmer with an offset base at work and I love it. It is far more steady on the edges because all the weight is over the wood and it isn't a balancing act to keep it straight. The only problem I have with it is it isn't built for heavy use so a full sized router wit that design would be great.
