Author Topic: Donkey Kong Jr Monitor Issue  (Read 1720 times)
munsonRoyE
  • Last login:March 05, 2010, 01:21:17 pm
« on: June 25, 2009, 09:31:42 pm »
Hi All!
I have installed a cap kit on a Sanyo 20ez monitor in my Donkey Kong Jr. arcade and everything looks great. The only issue I am having is a slight back and forth vibration on the screen. I tried adjusting all the pots, but nothing seems to help it. Any advice would be appriciated. Thanks!
Gonzo22
  • Last login:April 22, 2010, 12:52:23 am
Re: Donkey Kong Jr Monitor Issue
« Reply #1 on: June 25, 2009, 10:32:59 pm »
When you did the cap kit, did you replace the pots on the adjustment board? Sounds like a dirty pot somewhere.
I had this problem with my 2 board donkey kong, there was a slight shake in the picture that resloved itself after I turned the pot on the actual game PCB back and forth a few times because it was dirty or old. Maybe one of your pots is dirty too?
munsonRoyE
« Reply #2 on: June 25, 2009, 10:54:27 pm »
Well, the vibration seems to have stopped. I unplugged the game for a while then plugged it back in. The screen was rolling really bad, so I adjusted the V Hold. Everything looks fine now. Maybe the new caps justed needed time to warm up. If any other problems come up I'll let you know.
