Author Topic: Monitor adjustment in software (windows xp)  (Read 2065 times)
Hoagie_one
  • Um....whats a cabinet
« on: June 19, 2009, 05:13:01 pm »
My arcade monitor has about 1\8" at the top where the image is squished.  When I run mame, I can use the slider controls to stretch it downward so it doesn't show on the screen when I play, but in windows and in windows programs, its an issue.  You dont have all the detailed monitor controls on this old arcade monitor so I was curious if there is windows software that acts like the slider controls in mame but in windows?
Mike
Ummon
  • Trade Count: (+13)
Re: Monitor adjustment in software (windows xp)
« Reply #1 on: June 20, 2009, 05:42:26 pm »
If you're running at 15khz, stretching the image that way creates very obvious artifacts. Maybe in your case, it's so small an area, and that it's at the edge, means it doesn't mess up much. I dunno.
Yo. Chocolate.
Stephen Hawking
Hoagie_one
« Reply #2 on: June 23, 2009, 09:32:54 am »
It's very small and I notice almost no artifacts.  Just want to do the same on the XP front, any thoughts on this?
headkaze
  • Last login:May 01, 2026, 04:33:46 pm
  • 0x2b|~0x2b?
« Reply #3 on: June 23, 2009, 09:59:33 pm »
If you download the control panel software for your video card there should be settings in there that allow you to move the position of the screen around. Both ATI and NVidia have software to do that (usually installed along with the driver).
Hoagie_one
« Reply #4 on: June 23, 2009, 10:46:12 pm »
Its an arcadeVGA and I dont see any settings for that.
headkaze
  • 0x2b|~0x2b?
« Reply #5 on: June 24, 2009, 12:20:55 am »
ArcadeVGA is a repackaged ATI card. On the drivers CD you should be able to install the control panel software.
Hoagie_one
« Reply #6 on: June 25, 2009, 12:16:16 am »
ok, ill check it out.  Forgot to check the disk.
