Author Topic: 25k7193 Jail Bars - will a cap kit fix this ?  (Read 3465 times)
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« on: June 19, 2009, 03:17:31 pm »
I have some bars on my 25 WG monitor. It only affects the back ground and not all the time on every screen. The monitor picture is quite good except for the lines. I used a camera phone so the pix are not the best.
I looked at other posts / pictures of jail bars and never saw any quite like this. Is it normal to run through the background image only and not the on screen characters ?  Quite simply put, do you think a cap kit should fix it or might it be something else ? Thanks !
SirPeale
  • Green Mountain Man
Re: 25k7193 Jail Bars - will a cap kit fix this ?
« Reply #1 on: June 19, 2009, 03:19:43 pm »
Sorry to break it to you like this - those aren't jail bars.  Not monitor ones at least.  You have a board issue.
Kevin Mullins
    • Me on Myspace
« Reply #2 on: June 19, 2009, 05:29:46 pm »
Agreed..... those don't look like monitor "jailbars", they look like a graphics glitch.
Do you have another JAMMA board to throw in there?
Try carefully re-seating all your socketed chips on the game board.
tommyinajar
« Reply #3 on: June 19, 2009, 08:13:53 pm »
It isn't a standard jamma type board with visible chips. I guess it's called an "A & B" board like this-
This is the first Coin-op I ever bought with this kind of set up, don't know much about it at all. Anyone got any tips  ???
« Last Edit: June 19, 2009, 08:22:38 pm by tommyinajar »
« Reply #4 on: June 20, 2009, 12:34:08 pm »
try a different JAMMA game
and what you have is a Capcom CPS2 system
Oni2382
  • Last login:December 07, 2015, 11:00:36 pm
« Reply #5 on: June 21, 2009, 08:29:08 pm »
The 2 boards come apart. You need a Torx security bit in order to get the screws off to get to the chips. It's a shame. MVC is my favorite VS. game.   Good luck with this. If you need help locating a bit PM me and I can point you in the right direction.
XBL:Mykungfooizgood
PSN: Mykungfooizgud
SirPeale
« Reply #6 on: June 21, 2009, 09:55:23 pm »
I have Torx security bits for sale in my store.
Oni2382
« Reply #7 on: June 22, 2009, 05:07:35 am »
These are perfect for you tommy. One thing however I need to look and see if the screws are set inside the board. I guess a better way of saying this is making sure the screws aren't recessed (a hole than a half inch or so of space before you see the screw.) If they are then those bits will be too short to reach. In a few hours I will go home and check for you and I'll let you know. At any rate peale I will order something from you as I need to replace  some torx bits that I have misplaced. How fast do you ship..... :cheers:
XBL:Mykungfooizgood
PSN: Mykungfooizgud
Oni2382
« Reply #8 on: June 23, 2009, 04:49:23 pm »
I checked for you..The bits peale has for sale will work nicely...Order away.  :cheers:
XBL:Mykungfooizgood
PSN: Mykungfooizgud
