Author Topic: Topcoat over poly?  (Read 2568 times)
  • Last login:June 29, 2026, 03:23:15 pm
Topcoat over poly?
« on: June 14, 2009, 07:24:31 pm »
Does anyone know if there is anything I can put on top of some poly to make the surface even shinier/slicker?  I'm going to be putting about 6 or 7 coats of poly over some stained birch plywood and I want to get it real smooth.  I plan on sanding up to 600 grit (or maybe higher if I feel like it).  Can I put some wax or something else on top and smooth it out to 1000 or 1500 grit or should I just stick with the poly?
Any tips would be great!
pharmd99
  • Last login:September 14, 2010, 01:55:16 pm
  • "My parts are showing? My goodness."
Re: Topcoat over poly?
« Reply #1 on: June 15, 2009, 11:09:31 am »
« Last Edit: June 15, 2009, 11:14:02 am by pharmd99 »
« Reply #2 on: June 15, 2009, 09:02:19 pm »
stick with poly
http://www.woodweb.com/knowledge_base/Recoating_Over_a_Mystery_Finish.html
Hmmm...  I just sanded it down with 400 grit and reapplied a thin coat of poly.  I don't think I'll be able to buff it to 1000 grit because it will only be as smooth as the last coat, right?  Am I missing something?  How do people get such a smooth finish on furniture and stuff???
