Author Topic: Making TV turn on when I turn on the power  (Read 2536 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: June 11, 2009, 07:07:58 pm »
Ok, I know that there have been threads about bridging the power switch, but the TV I have in there, an apex flat 24 inch doesn't seem to want to do that.  Does anyone have any suggestions?
Ginsu Victim
  • Last login:June 29, 2026, 04:15:57 pm
  • Comanche, OK -- USA
Re: Making TV turn on when I turn on the power
« Reply #1 on: June 11, 2009, 10:18:20 pm »
If your Apex is like most, this should work:
Turn it on.
Turn the volume down to zero.
Hold MUTE on the remote while holding VIDEO on the TV (or MENU if that does nothing).
You should now be in the service menu.
Find OPT.PWR-ON 0 and set it to 1. (EDIT: This is wrong. I'm trying to figure out the right option)
Turn off TV.
Now it should turn on when you give it power.
Hope it works for you. If not, run a google search "Apex model xxxxxxx service mode"
« Last Edit: June 12, 2009, 08:13:55 am by Ginsu Victim »
iscariot
« Reply #2 on: June 11, 2009, 11:26:46 pm »
That's the problem.  I don't know what model it is.  I acquired this cabinet and was told it was an apex.  Is there a way to ID it based on the board?  I only have the buttons:
Power
Channel+
Channel-
Volume+
Volume-
Menu
It's got component, svideo, composite, and tuner.  Composite is on the front and back.
Ginsu Victim
« Reply #3 on: June 12, 2009, 08:16:38 am »
Problem is, I'm not sure of the correct option right now. Last night, we had no power for three hours and when I got up, the TV was on when it shouldn't be. I'm looking into it.
As for your model, I have no idea how to find out what it is.
Kevin Mullins
    • Me on Myspace
« Reply #4 on: June 12, 2009, 02:17:07 pm »
As for the model..... shouldn't there be a label right on the back with all that information?
A little capacitor trick Peale wrote up for PC's could possibly also be applied to TV's.
http://www.pealefamily.net/tech/captrick/
Ginsu Victim
« Reply #5 on: June 12, 2009, 03:00:55 pm »
Sounds like it was decased when he got it.
Kevin Mullins
    • Me on Myspace
« Reply #6 on: June 12, 2009, 03:23:54 pm »
Now that could be a problem identifying it then.   ???
iscariot
« Reply #7 on: June 13, 2009, 03:02:03 pm »
Ok.  It's a Sanyo DS24425.  ANyone know the service mode for it?
Ginsu Victim
« Reply #8 on: June 13, 2009, 03:27:17 pm »
I've searched, and all I can find is people asking for the code, so I'm not sure you'll be messing with service mode any time soon.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #9 on: June 13, 2009, 07:56:29 pm »
i do have the service manual for this model in pdf
there is nothing in the service menu for what u seek.
found the owners manual , and that has nothing as well.....
however, a simple circuit can be constructed to initiate the tv's pwr on sequence.
pm for more info
qrz
