Author Topic: Xbox 360 controller hack probelm: L initially activates LB?  (Read 1499 times)
purplearms
  • Last login:January 01, 2011, 09:12:12 am
Hi everyone..
i just finished pad hacking a 360 controller and installed it into a nubytech SF anniversary controller. Everything works fine except one thing: When I press left (directional), it initially activates left shoulder instead (they both share a common ground with the sync button). If I keep holding left, it starts to work but only after initially getting left shoulder.
I can't access the top side of the PCB because everything is already wired and the PCB epoxied (left was working initially so i dont know what the problem is now), but I can still access the via holes on the other side (battery side). I soldered two wires to the left directional pad, and for left shoulder and sync i shared the ground (they both work fine).
Has anyone experienced this before?
my 360 PCB is identical to this
http://www.slagcoin.com/joystick/pcb...0_diagram5.jpg
Voltages:
Sync = 1.734v
Left shoulder = 1.328v
Left = 1.286v
