Author Topic: Monitor Help for a noob  (Read 1746 times)
bookoute
  • Last login:November 12, 2009, 04:14:49 pm
« on: May 14, 2009, 10:48:03 am »
I have recently happened upon a wg k7000 25" monitor and need some help diagnosing... er planning for my next steps. Could this be a bad flyback? If you cant tell by the pic There is a dominant Green tint and the Red and Blue are distorted/muted. There is also some horizontal bending going on.
« Last Edit: May 14, 2009, 11:02:59 am by bookoute »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Monitor Help for a noob
« Reply #1 on: May 14, 2009, 04:46:46 pm »
it isn't ur fly . the fact that u HAVE a pic eliminates that .
the chassis likely needs some 'lytic capacitors replaced .
most folk here seem to favor the shotgun approach with model specific "cap kits"
the crt appears to be  weak .  rejuvination will likely perk it up considerably.....
qrz
bookoute
« Reply #2 on: May 14, 2009, 07:53:01 pm »
I just replaced the caps and no change in the picture. I have a 19" tube that I can use to test the chassis. I heard that rejuvenating the tube can kill it, so it would probably be best to invest in  a new tube. If you can think of anything else that it could be please let me know.
qrz
« Reply #3 on: May 14, 2009, 10:01:05 pm »
yes, an improperly done rejuve might damage a crt.  if extreemly weak , what do you have to lose by trying ?
if the cathodes are in fair condition , the process should considerably improve ur pic .
used crt testors/rejuvinators can be had on ebay for much less than new
pd a $1000  new for my cr70 back in '84
http://cgi.ebay.com/Sencore-CR70-BeamBuilder-CRT-Analyzer-Rejuvenator_W0QQitemZ220411779667QQcmdZViewItemQQptZBI_Cellular_Optical_Television_Test_Equipment?hash=item335190da53&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
qrz
bookoute
« Reply #4 on: May 14, 2009, 10:27:23 pm »
Ha, makes it seem like a steal when you put it that way. Thanks for the tip.
qrz
« Reply #5 on: May 14, 2009, 10:34:52 pm »
the majority of equipment i own were purchased new .
so, it is quite nauseating to see how low some items are selling   :badmood:
qrz
bookoute
« Reply #6 on: May 15, 2009, 12:41:58 am »
Sorry about that. Hopefully you've had the chance to make a good flip to get your money's worth.
So I have spent the past couple of hours on further diagnosis. I have hooked up the Jamma board to another monitor that I have and it looks brilliant. I then swapped chassis and behold it looked crappy so... It's definitely in the chassis (hopefully the tube's good I'll test that tomorrow to be sure). Now that I have concluded this what wold be my next steps. Already did the cap kit, the HOT and the flyback shouldn't effect this...
qrz
« Reply #7 on: May 15, 2009, 10:11:44 pm »
did ur "cap kit" include caps for the neck board ?
if its the board i'm thinkingof , there are 3 caps for rgb input to the lm1203   ~ 10uf/16-25v
there is also a b+ filter cap for the ic  220-470uF/16-25v
also check the 4.7-10uf/250v .
it may then need some minor adjustments ( tweaking )
qrz
