Author Topic: Quick TAF Question...Does each NEW BALL give you a GREED Letter?  (Read 5093 times)
Charles4400
  • Last login:February 18, 2016, 02:31:42 am
I modified my previous post, I was incorrect I was not getting a GREED letter within the swamp, but with each new ball no matter where it lands.
So is it normal to get a new GREED letter with each new ball?
Mine does, is it supposed to?
« Last Edit: April 19, 2009, 11:57:40 pm by Charles4400 »
tomdotcom
  • Last login:March 05, 2014, 11:55:56 pm
Re: Quick TAF Question...GREED & Swamp
« Reply #1 on: April 19, 2009, 11:56:23 pm »
On mine every time you start a new ball it gives you a letter in Greed. That is probably what is confusing you? I also replied to your RGP post :)
« Last Edit: April 20, 2009, 12:36:36 am by tomdotcom »
=-= Pins: Fishtales, Bram Stoker's Dracula, Revenge from Mars, Skateball =-=
=-= Custom Mame cab =-=
Charles4400
Re: Quick TAF Question...Does each NEW BALL give you a GREED Letter?
« Reply #2 on: April 19, 2009, 11:58:22 pm »
rewrote my last message just as you posted yours!
Thanks I feel MUCH better now thats its working correctly!
tomdotcom
« Reply #3 on: April 20, 2009, 12:33:20 am »
No problem, I thought mine was messed up too actually. But then when I read through the rules with a fine tooth comb..I found the part about getting a letter for free..for each new ball!
**edit** You can actually turn that feature off in the settings menu if you want.
Cheers!!
« Last Edit: April 20, 2009, 12:36:18 am by tomdotcom »
Mauzy
« Reply #4 on: April 20, 2009, 08:33:42 am »
Whew. I was about to be pissed that the TAF I always played was malfunctioning- I've never played one with the free GREED leter on... That op makes us WORK to get into the vault  ;D
Charles4400
« Reply #5 on: April 20, 2009, 01:54:21 pm »
Cheers!!
Hey Tom, do you remember where in the rulesheet it said that about new balls and greed letters?
tomdotcom
« Reply #6 on: April 20, 2009, 04:27:20 pm »
On your first multiball, the first switch you trigger each ball spots a letter. You can also gain a "cheat" GREED letter by tilting. When G-R-E-E-D is spelled, the bookcase opens and the vault is revealed.
Charles4400
« Reply #7 on: April 20, 2009, 04:38:48 pm »
I saw that but I got from it that this happens after you get a multiball..... but upon game start each new ball is giving a greed letter before any multiball has been triggered. Is this the same with your TAF?
btw...rephrased my question rgp to make it more clear, some people have chimed in:
http://groups.google.com/group/rec.games.pinball/browse_thread/thread/265b74fe0d32863f#
tomdotcom
« Reply #8 on: April 20, 2009, 04:40:48 pm »
No it means before you get your FIRST multiball you get a free letter on each new ball. Once you get past the first multiball it doesnt happen anymore. TRUST me. Thats the way it works..PERIOD..
tomdotcom
« Reply #9 on: April 20, 2009, 04:53:50 pm »
I replied to your RGP post as well (awesomejaret) under my sons account by accident haha..anyhow..you can stop worrying now cause your machine is fine..it's supposed to be that way
tomdotcom
« Reply #10 on: April 20, 2009, 05:54:07 pm »
You can make TAF as easy as hard as you want really. So I don't see it as an issue. Pretty much every setting can be increased or decreased.
tomdotcom
« Reply #11 on: April 20, 2009, 06:30:04 pm »
hHAHA too funny..just play it blindfolded then if its too easy :P
Charles4400
« Reply #12 on: April 20, 2009, 08:08:54 pm »
No it means before you get your FIRST multiball you get <a onMouseOver="javascript:window.status='a free';return true;" onMouseOut="javascript:window.status='';return true;" href="http://canadasrv.info?v=1%2E2&ss=a+free">a free</a> letter on each new ball. Once you get past the first multiball it doesnt happen anymore. TRUST me. Thats the way it works..PERIOD..
Thanks Tom, I hate being paranoid about a game that was just fixed up, didn;t know if I goofed on a repair or what! Glad its working as it should...once again I feel much better  ;D
Appreciate the feedback, tested and confirmed, after your first multi-ball you stop getting GRED letters on a new ball.
Thanks Again!
tomdotcom
« Reply #13 on: April 20, 2009, 08:35:04 pm »
My pleasure, TAF was my first pin and I'm very partial to it :) Least I could do to help out the community
